AUM blown AGU replace?
bp1984 Apr 28, 2012
  1. bp1984
    bp1984 New Member
    Ive been offered today a 2000 1.8t with engine code AUM but the engines totally shagged, But theres a working 1998 AGU engine at work just sat waiting to be put into something. So just wondered if theres alot that would need changing to make it run ok eg. ECU or pipework or is it a simple drop in and drive off? Any info appreciated cheers
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    78
    Short answer no it wont just drop in and drive. Find out what is wrong with the aum engine and swap the components over from the agu. But keep the ko3s turbo from the aum, the agu turbo is pants.
  3. Prawn
    11,639
    3,628
    drop the AGU in, it'll be fine.
    You'#ll just need to run all the sensors and ancillaries from the AUM, but that's no hardship.
    You will need to swap over the VVT tensioner and stuff also to keep that working, but again, if you're contemplating an engine swap, I doubt a VVT tensioner is going to phase you....
  4. FJ0372
    FJ0372 New Member
    22
    I actually happen to be in the process of doing the exact same thing. I have a wrecked AUM and can only get hold of an AGU at a decent price. If I run all the sensors and ancillaries from the AUM on the AGU will VCDS not come up with any faults once the change is complete?
    Thanks in advance for any replies that are helpful.
