audio upgrade
tja Oct 7, 2008
  1. tja
    tja Member
    Anyone got any thoughts or advice re the following?
    Currently have A4 B5 with symphony double din and phatbox - thinking of swapping to Pioneer satnav double din with ipod connection, and swap front speakers for something like Diamond in original doorcards.Then remove rear shelf speakers altogether, and replace with single sub in boot and mono amp to match.Does this sound ok or has anyone out there (the usual suspects!) got any better ideas?
  2. AndyMac
    9,832
    46
    Sounds like a good plan, you'll need adapters for the front doors and bear in mind the plastic ones are shyte so you're better off making your own from MDF, but space is severely limited. It's not so much the depth that's the problem on the B5 but just squeezing a 5.25" speaker into a space with a lot of metalwork in the way. I had to carve off a few mm's of the door frame to fit my Rainbow components.
