Audi V8 Engine on Ebay
aragorn Mar 10, 2009
  1. aragorn
    18,303
    805
    http://cgi.ebay.co.uk/Audi-4-2-V8-Engine-Gearbox_W0QQitemZ270352995193QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item270352995193&_trksid=p3286.c0.m14&_trkparms=72%3A1689|66%3A2|65%3A12|39%3A1|240%3A1318
    Someone might be interested in that for their A4 :)
  2. aragorn
    18,303
    805
  3. PhilR
    PhilR One Ate Tea
    332
    how much work is involved in fitting one of these ?
    I've read threads on here recently implying its an easy swap yet i have never seen one finished.
    I know Siena is going to tackle it, but the only one i have heard of running is the cosworth (correct me if im wrong) prototype for the b6 s4 which involved building a v8 b5, i seem to remember reading that the front had to be extended etc
  4. Lee Goodall
    Lee Goodall Active Member
    2,279
    Wonder what service history it's got?
  5. aragorn
    18,303
    805
    Phil: the engine block itself is not really any longer than the AEB. removing the viscous fan should easily provide enough room to fit it in the A4 bay, without having to cut away anything or hack about. The inlet/thorttle assy is larger, but it overhangs the rear of the motor, and theres enough room between the engine and bulkhead for this to fit.
    I suspect the prototype car will have used a dual mass flywheel, and this requires a rather thick spacer between the block and the engine, pushing the engine forward.
    Remember the 30V V6 is the same motor but just a cylinder shorter, and runs the Dual mass spacer, and there is plenty of room around those.
  6. PhilR
    PhilR One Ate Tea
    332
    I see, that makes sense
    I wonder what mating the wiring up would involve
  7. aragorn
    18,303
    805
    phil: theres only a handful of wires, power, few senders for things like coolant and RPM and the 3? wires for the immo1 box.
  8. PhilR
    PhilR One Ate Tea
    332
    i assume there is a lot more involved if you want to run it on standard A8 Engine managment though?
  9. Siena
    Siena Active Member
    2,626
    V8...rumble..rumble..rumble. :ninja:
    V8...burble..burble..burble. :ninja:
    B5 + V8 + turbo / Eaton...rumble...burble...woosh...tssssssh! :whistle2:
  10. Lee Goodall
    2,279
    You must be about finished yours now?
  11. Siena
    Siena Active Member
    2,626
    I wish! So busy right now, and the weather's not helping either.
  12. Lee Goodall
    2,279
    Yeah we need some warm dry weather so people can get projects up and running.
  13. aragorn
    18,303
    805
    Nah, thats for the stanadrd management. The loom itself is pretty self contained, with only a few connections back to the car itself.
  14. Broken Byzan
    13,237
    465
    I agree.
    Next few days will be fine for me or i get wet i suppose
