Audi Uk, Watchdog or VOSA after injector recall?
monkeynut Jul 22, 2012
  1. mike foster
    3,967
    I have no idea but I put that in my answer because Audi sell a DPF kit for retrofitting to BKD engines so someone may have done it.!!
    What I should have said is that the 140 BKD engine does not have a manufacturer fitted DPF !
  2. SootySport
    SootySport Well-Known Member Team Silver
    2,757
    732
    What, no DPF on any year? Thats good news then.
  3. mike foster
    3,967
    Not on a BKD engine :icon_thumright:
  4. c_w
    c_w Well-Known Member
    1,163
    87
    This confirms my suspicion that they did alter the ECU software on the injector swap, when I compared a VCDS engine coding before and after there were slight differences but most people said there's wasn't changed!
    In mine I have noticed the kangarooing, it does it more with me driving than my girlfriend who tends not to drive slow/steady at slow speeds. As people have said you can drive through it so it's not a "misfire" as such probably just poor mapping perhaps.
    I have also noticed the increase in DPF regens during driving which makes the throttle inconsistent and gives the occasional "hiccup" at light throttle that does feel like a misfire.
    I personally wouldn't go chasing other solutions like pipes/egr when it wasn't doing it before! I could be wrong but I would just put it down to the injector replacement and the software "update", maybe VAG will come up with another software update to smooth the throttle at light speeds?
  5. Originalgeezer
    Originalgeezer Member
    59
    Audi A3, 2007 MY 170bhp......Had stutter when cold between 1500 to 2500 rpm, before Injector Recall. Booked the car in, for the recall to have injectors replaced before looking into the stutter, hopeful this may actually be the cause. Collected the car, drove up the road and still the stutter - excellent road test that must have been.
    So, having looked into some of the various potential causes of the stutter I replaced the fuel filter and hey presto, no more stutter. However, 3-4 weeks later I have now had the DPF Light come on. As I do 90 Motorway miles each working day this soon cleared. But I phoned Audi Uk Customer Services highlighting this and stated if I believed a fault was caused through the replacement of the injectors I would hold them liable for all costs. They have promptly called, whilst not admitting liability they have said because I have raised this, then if a fault develops to speak to my local dealer. The local dealer has been told to call Audi Uk to then discuss the fault.
    The next day, you guessed it the DPF came on again. Another trip to work and the DPF light has gone out. So, will in due course see how this goes and post back on results of dealing with Audi Uk Customer Services and Local Dealer.
  6. c_w
    1,163
    87
    I would guess the threshold for the DPF light coming on is now lower than before to avoid the issue of regeneration failure if it doesn't clear before a certain level. As has been said the regeneration happens a lot more than before to keep the DPF at lower content levels and perhaps now the DPF light which is a secondary stage regeneration is now at a lower setting too.
  7. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,255
    586
    Get it removed, you won't regret it, they drive sooo much nicer.
    Rick
  8. c_w
    1,163
    87
    Rick, is this something you can offer?
  9. Rick @ Unicorn Motor Dev.
    1,255
    586
    Hello,
    yes it is something we have a lot of experience with :)
    Rick
  10. Hi guys
    im getting this on my 56 tfsi petrol?? Audi aren't being helpful and no o/s recalls. Had coil pack done but still juddering on idle and juddering until temp reached any thoughts
