audi tt mk2 haldex failure
summa1988 Sep 2, 2013
  1. summa1988
    summa1988 New Member
    the other day driving home i got Tyre Pressure Malfunction warning on the dash and now have no traction and 4wd at all. ive had my friends laptop connected to it and it says
    Address 03: ABS Brakes Labels: 8J0-614-517.clb
    Part No SW: 8J0 614 517 A HW: 8J0 614 517 A
    Component: ESP MK60E1 0020
    Revision: 00H60001
    Coding: 0083827
    Shop #: WSC 01236 785 00200
    VCID: 2B517F7A8A8D6740A59
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 25
    Mileage: 65987 km
    Time Indication: 0
    Date: 2013.07.05
    Time: 11:38:20
    Freeze Frame:
    Count: 192
    Count: 773
    Count: 8212
    Count: 46080
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    Shop #: WSC 00000 000 00000
    VCID: 438137DA021D8F007D9
    1 Fault Found:
    00448 - Haldex Clutch Pump (V181)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 11000000
    Fault Priority: 2
    Fault Frequency: 57
    Reset counter: 48
    Mileage: 3618101 km
    Time Indication: 4
    Freeze Frame:
    Count: 768
    Raw, Form. N/A: 000 000 000
    Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
    Part No SW: 8J0 907 274 B HW: 4F0 907 274
    Component: J502 RKA+ H02 0150
    Revision: 00000000 Serial number: 00008380033636
    Coding: 0603100
    VCID: 316D6D12A8A10D909F5
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 3
    Fault Frequency: 27
    Reset counter: 35
    Mileage: 67450 km
    Time Indication: 0
    Date: 2013.08.06
    Time: 16:26:16
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0000
    Hex Value: 0x0007
    Voltage: 14.00 V
    Temperature: 20.0°C
    (no units): 68.0
    End ---------------------------------------------------------------------
  2. summa1988
    ive managed to get a cheap second hand rear diff but don't think i dare replace it myself as it be really hard on my axle stands :(
    the haldex unit was serviced at 20,000 and its just hit 40,000 but i have serviced it yet. is it worth changing the oil on my faulty haldex first to see if it fixes it or well that by a waste of time/money.
