Audi TT - 3 day Major
Jimmeh Sep 9, 2011
  1. Jimmeh
    Jimmeh Active Member
    1,438
    Hi all - here's my latest Audi installment that may be of interest.
    Audi TT – Major Paint Correction Detail
    Take an Audi that has clocked 85k miles, been through the hands of 8 previous owners and is 9 years old. Unless it’s been properly cared for in the past, chances are, it’s ready for a bit of TLC!
    Over three days my aim was to put as much life back into the paintwork as possible, tidy the engine bay and fully deep cleanse the interior with leather treatments.
    Product: AMDetails. AutoSmart. BlackFire. Jeffs Werkstat. LTT. Menzerna and Scholl Concepts.
    The vehicle was put through its wash stage late on a Sunday evening – “why?” Monday, first thing, I had organised a dent repair chap to pull a few of the nasty dings out. No photos unfortunately, but I must say, he did a fantastic job! (Watch this space)
    Picking up where I’d left off, surface contaminants were removed by using a clay bar.
    Lots of pick up to be seen:
    With the car now ‘clean’, it was blown dry to remove excess water from panel gaps, trim, badges etc and then taped up in readiness for some machine polishing.
    It was noted that A) the wheels had been badly refurbed (blown over the front-facing but lots of overspray and dirt stuck in the inner rim), B) the front bumper had been repainted and C) the rear bumper had been repainted (badly)
    Inspection shots.
    Resprayed areas:
    Dull and hazy:
    Wings covered in overspray and buffertrails:
    Rear bumper, an area of caution this due to the poor spray work:
    Lower down on rear bumper, there was NO life at all!
    Other than that, general swirling and bad scratches!
    Even with the nature light from the window, you can see how bad some areas were:
    More nasties:
    [​IMG] [​IMG]
    Overspray:
    More buffertrails from previous machine polishing:
    A few areas that really were quite tatty:
    And a bird etching thrown in to complete the set:
    Good. OK. Plenty to get stuck into then!!
    Paint thickness readings on the bonnet: (enough to play with)
    [​IMG] [​IMG]
  2. Jimmeh
    1,438
    My first 50/50:
    Corrected and refined.
    [​IMG] [​IMG]
    The TT isn’t an easy straight forward shape to work with… Lots of flowing curves but also fiddly areas that require special attention and lots of tape to safely cover.
    Top of the boot lid, before/after:
    Side of the boot lid, before/after:
    Roof, with healthy paint thickness readings, before/afters:
    Refined and sharp:
    A-C Pillars - before, in-action, after:
    Keeping the correction as ‘tight’ as possible, the smaller flat sides to the wheel arches were hit first with a series of spot pads:
    …before the rest of the area was tackled. 50/50:
    Wing mirror housing before/after:
    More spot pad work – before/after:
    Insides of the grab handle polished with Menz 203s – before/after:
    50/50 on the offside between the wing and the door:
    Before/after:
    Audi-Rog likes this.
  3. Jimmeh
    1,438
    The section around the fuel filler was a nightmare. Patience, overlapping tape and slow passes required here.
    Before/after:
    Before/after:
    O/S/R wing complete:
    The boot lid was in a bad way. Someone, somewhere down the line, seemed to have a habit of resting things on the paint whilst opening up…
    Closer up:
    Time to get aggressive.
    First up, the angled leading edge was hit first – before/after:
    And after some heavy hitting with wool, I was left with these results:
    Most impressive!
    Something you don’t often see, my own buffertrails! (Numerous ‘heavy hits’ with an aggressive polish/pad combo takes its toll)
    After refining stage:
    Before/after:
    Spoiler before/after:
    Boot lid after:
    Light clusters before/after:
    Final section on the boot – before/afters:
  4. Jimmeh
    1,438
    Spinning the car round, work beings on the N/S.
    N/S/R wing before/after:
    “hmm, overspray!”
    N/S/R complete:
    Correction around N/S door handle:
    [​IMG] [​IMG]
    And front wing, before/after:
    Finalising work on the bonnet:
    Check out the difference in clarity in this next photo… Clarity between the top of the bumper and the bonnet itself:
    Bulk of the correction now complete. Just the bumpers and sills to go.
    Before/after:
    The O/S/R corner had a nasty scrape on it… Treading carefully here as the paint finish wasn’t the best.
    Before/after:
    The only way the rear bumper will ever be perfect is if it has another (proper) respray. Much improved though for now…
    Lower down, the scrape continues – before/after:
    Little middle section – before/after:
    And finally the lower part that had no life at all.
    Better:
  5. Jimmeh
    1,438
    Sill work – before/after:
    The leading edges were a bit rough; 9 years of people clobbering them with their shoes.
    Attempted befores and afters:
    and the O/S:
    Before/after:
    With heavy paint correction comes heavy dusting! Before we can think about wax, protection, glass etc, we need to rid all surface debris.
    After a quick foam, a thorough pressure wash was given; concentrating on trim, panel gaps, crevices, sills and shuts etc…
    Rinsed with an open hose to sheet the water off of the panels (far easier to dry afterwards!)
    With the car back inside, fully dried down, engine bay dressed and paintwork wiped with IPA, I looked towards the protectional stages.
    Product of choice? Had to be BlackFire.
    BlackFire ‘Wet Diamond’ All Finish Paint Protection.
    Allowed to cure for 15 minutes before buffing.
    Although out of focus, these next shots are before/afters on the exhaust tips. Belgom Alu and 00 grade wire wool. Came up quite good in the end!
    Glass cleaned, exterior ‘toothpickery’ (removal of remaining trapped residues etc) and wheels sealed. Time to check out that interior…
    Doesn’t show too well on the photos, but, lots of room for improvement. Shiny, dirty leather. A dirt encrusted gear knob, tacky indicator stalks and grubby plastics all round.
    Leather ‘brushed’ to remove trapped dirt from sides of bolsters. Hoovered. Plastics wiped with weak AS G101 mix. Toothpick used to lift engrained dirt in gear knob numbering and finally the Leather was deep cleansed with LTT’s Auto Ultra Foam. (Re-hoovered!)
    After:
  6. Jimmeh
    1,438
    Boom. Three days later, we have an Audi TT fit for ANY showroom!
    Correction levels:
    Enjoyed this one! Both physically working on the car and documenting it! An awesome ‘save’ and a mega turnaround.
    My ‘Pamper-Pack’ kit (essential DIY products) was passed on to the new (delighted) owner and they hope to revisit in 3-4 months for a top up.
    As always, thanks for reading and thanks for the continuous support!
    Jim
  7. Ben H
    Ben H On a journey...
    365
    19
    That is an absolutely stunning turnaround - really enjoyed seeing this. :)
  8. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    Absolutely stunning Jim :icon_thumright:
  9. Sean_S3
    Sean_S3 Member
    323
    17
    Awesome work , I bet the new owner hardly recognized the car the differance is so big.
  10. stunning work Jim, was the Blackfire AFPP at clients request or your choice? looks great whatever
  11. si hoc
    si hoc Member
    108
    nice work mate
  12. kevscotty
    kevscotty New Member
    19
    nice work :yes: how much does a detailing like that cost if you dont mind me asking?
  13. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    im speachless m8 that is the best correction work ive seen
  14. Smokey_clark
    Smokey_clark 12th Gear
    210
    Great job there Jim!
    I am also intrigued with what you might expect to pay for just the paint correction work.
    I can keep my interior clean and don't have much of a problem protecting and cleaning my paint but i suffer with the condition the car came to me in the first place! Wish i had the balls to get a polisher onto it!
  15. Jimmeh
    1,438
    Thank all! :)
    Cheers Ben. Must admit, can sometimes take as long to write the report as it does to wash the car in question! (worth it in the end tho! ;) )
    Was my choice. It's to be a regular visitor for top-ups etc so for ease of use and looks, it was 'the one'!
    Pop over an email if you could guys or find me on FB on the link below. Cheers!!
  16. not posted this one on detailing world yet mate?
  17. Audi-Rog
    Audi-Rog Six Audi's & Counting!
    255
    79
    Awesome work Jim! Superb turnaround mate!
    That's why I went into Detailing (part-time) myself! The pure satisfaction of reviving/rescuing a really poorly looked after car and making it desirable again, is priceless!
    Loving your work ethic too, so much passion, skill and pride, it really shows! And it's the reason you are so busy!
    Rog :icon_thumright:
  18. butler2.8i
    butler2.8i Member
    184
    23
    Stunning work Jim and a top class write up matey
  19. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    great work Jim. How come you dont seem to be on DW recently?
  20. Wozski
    Wozski Member
    522
    Drools!!! :hubbahubba::applaus:
  21. nally
    nally MPG the new BPH
    2,104
    34
    love looking at these just wish i could do it
  22. BarryM
    BarryM Member
    61
    very impressive!
  23. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    as always top job, what do you use and the method for rear lens to get rid of the scratches?
  24. A-k
    A-k Member
    79
    Great turn around black is a great colour for seeing results
  25. Jimmeh
    1,438
    I haven't posted anything on DW in years chaps? I lurk from time to time, new products, news etc. I used to post in the Showroom a long time ago - since, I've not really looked into the Studio/Supporters scheme (seem to be doing alright as it is! :) )
    Cheers mate - appreciated.
    I tend to reach for Menz 203s when working on the rear clusters. A light/medium cut polishing pad and low speeds to keep temps down. By hand? You could try Menz 203s on a lake country polishing pad (see polishedbliss' posts) or even the Megs Plastic-X system (no experience in using this though)
    Thanks again!
  26. xyz1
    xyz1 Member
    52
    excellent thread and great work!
  27. Steven.c
    Steven.c Auto-Motive Restored Deatail
    282
    seen this write up and all of your others on CYC, your work is outstanding!
