Audi TT 3.2 DSG ECM and Starting Issue
vaslam1986 Jul 16, 2013
  1. vaslam1986
    vaslam1986 New Member
    Really in need of some help here guys. Got a MK1 TT (04) for a cruise control retrofit, oncee i completed the retrofit and put everything back together only to find that the car does not start. The PRNDS on the DIS is constantly flashing. The car does not turn over at all. I ran VCDS scan on it and have found that there is no communication with the ECM. I checked all the wiring etc and still no joy. As a last resort, i've taken the cruise control stalk and wiring out but still no joy. Any help ideas will be greatly apprciated.
    VCDS Log:
    VCDS Version: Release 11.11.6
    Data version: 20121223
    Tuesday,16,July,2013,21:30:24:15161
    Chassis Type: 8N - Audi TT
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    VIN: TRUZZZ8N941024501
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 046 F HW: 02E 927 770 L
    Component: GSG DSG 0603
    Revision: 03149888 Serial number: 00000402140099
    Coding: 0000020
    Shop #: WSC 01236 785 00200
    VCID: 1A3DEC2BD6A480C8CEF
    1 Fault Found:
    18258 - Powertrain Data Bus
    P1850 - 000 - Missing Message from ECU
    Address 03: ABS Brakes Labels: 8N0-907-379-MK60-A.lbl
    Part No: 8N0 907 379 K
    Component: ESP ALLRAD MK60 0102
    Coding: 0022548
    VCID: 4481725304A0E638443
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication
    Address 08: Auto HVAC Labels: 8N0-820-043.lbl
    Part No: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00041
    Shop #: WSC 01236
    VCID: 2859C6E3C8C8225848B
    No fault code found.
    Address 15: Airbags Labels: 8N0-959-655.lbl
    Part No: 8N0 959 655 D
    Component: Airbag Front+Seite 0000
    Coding: 01102
    Shop #: WSC 01236
    VCID: 418F7B474BB2F3106F5
    Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
    Part No: 8N2 920 980 D
    Component: KOMBI+WEGFAHRS. M73 D14
    Coding: 01462
    Shop #: WSC 00847
    VCID: 387916A31868B2D8D8B
    TRUZZZ8N941024501 AUZ5Z0D1265042
    4 Faults Found:
    01177 - Engine Control Unit
    64-10 - Not Currently Testable - Intermittent
    49-00 - No Communications
    01304 - Radio
    49-10 - No Communications - Intermittent
    01305 - Databus for Infotainment
    37-10 - Faulty - Intermittent
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 D
    Component: HALDEX LSC ECC 0011
    VCID: 214FDBC7ABF2D3100F5
    1 Fault Found:
    Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
    Part No: 8N8 962 267 E
    Component: Zentralverrieg.,DWA D09
    Coding: 06858
    Shop #: WSC 01236
    VCID: 4383714F51AEE1007D9
    4 Faults Found:
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01559 - Drivers Door
    58-00 - Can't Lock
    60-00 - Won't Safe
    01134 - Alarm Horn (H12)
    76-10 - Terminal 30 missing - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8N8 951 177
    Component: Innenraumueberw. D09
    Coding: 00001
    Shop #: WSC 00000
    VCID: FCF14AB3ECD0DEF8FC3
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00010
    Shop #: WSC 01236
    VCID: E5C70FD77F5A7F3033D
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 4B0 035 152 E
    Component: chorus II GRO 0001
    Coding: 00302
    Shop #: WSC 01236
    VCID: 1B33E92F899EF9C0D59
    1 Fault Found:
    00856 - Radio Antenna
    36-10 - Open Circuit - Intermittent
    End ---------------------------------------------------------------------
  2. NHN
    29,284
    1,695
    No comms with ecu, so its either fuse or wiring related, unless you've shorted something on the ecu & fried it somehow.
  3. vaslam1986
    Thanks for the reply, I've checked the wiring and fuses and they seem to be ok, guess I'll have to find someone more experienced to have a look at it for me. Anyone recommend someone up in glasgow or surrounding areas that can check this out for me?
