Audi transplants facelift onto pre-facelift
AR-rkon Oct 9, 2010
  1. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    Hey all,
    Can anyone tell me what external parts can be directly transplanted onto my 8L? (Ie: headlights/tail lights, bumpers etc...)
    also, will an S3 exhaust fit straight onto my 8L 1.8? (thinking cat back...)
    cheers.
  2. jojo
    28,856
    3,516
    Non of it!
  3. 1animal1
    9,978
    dust caps
  4. AR-rkon
    1,913
    165
    ****... sorry my mistake.... thought the facelift 8L was designated the 8P.
    I meant the facelift 8L... sorry for the confusion...
  5. jojo
    28,856
    3,516
    Well in that case, what exactly are you trying to do? From your first post, I'm guessing you have an early 1.8 20v n/a(non turbo). The Exhaust is 100% won't fit, as you don't have a turbo for a start, and because an S3 has quattro, the rear suspension is totally different.
  6. 1animal1
    9,978
    then the question is quite large....pre and post FL are by and large the same car.... main diffs are the one piece front lights which you can make fit a prefacelift, then its loads of subtle things....bar the engine of course, i wouldnt worry about that though as both map up the same
  7. AR-rkon
    1,913
    165
    all im trying to achieve is to "spruce" her up... lights are faded and looking dated (plus like the look of the facelift ones) guess im really just trying to make the audi look a little newer. As for the exhaust, fancy something poking out the rear apron, pref a twin.
    Interior wise: I'd love to fit a double DIN head unit. Did the 8L Facelift ever come with a double din headunit (so i can use the centre from that) or do i have to make one from Fibreglas?
    cheers
  8. 1animal1
    9,978
    rear lights are a direct replace, fronts you will need to do a slight cut on the inside lips of the wings (do a search for instructions)......yes there is a double DIN console for use with Audi double DIN units..... you ideally need to find someone to swap with though as you will need a new climate unit (assuming you have climate) along wqith the whole of the centre console which by all accounts is a bitch to change.....
    what have you got exactly, A3 or S3 and what year/model
  9. AR-rkon
    1,913
    165
    yep, just found the headlight mod...
    yes i have climate, but when you say about finding someone to "swap" the console with? could i not rob the centre console and constituent parts from a scrapper or similar? what parts are actually needed?
    car is a '97 A3
  10. AR-rkon
    1,913
    165
    any reccomendations?
  11. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,503
    1,424
    Before you go down the route of getting a double-din HU fitted, know that you will either have to fabricate a facia adapter yourself, or have someone do it for you. I have not found any adapters for this and had to cut an A4 facia to make my stereo fit.
  12. felga
    felga New Member
    Hi
    I`m trying to find solution , facelift climate controll in pre-facelift car (98), I Already have double din sat nav radio, modified cage and a4 facscia trim and loom but cannot make the climate unit to start in. I accualy have 2 of those now :/
    Andrew
  13. coyle
    coyle From Show... to GO
    435
    could someone point me in the direction of the facelift headlight conversion thread.. cheers
