Audi Symphony & iPod Connection Options
936ADL Feb 7, 2008
  1. 936ADL
    936ADL Member
    41
    Hi all,
    I've just purchased an A6 that's fitted with a Symphony Head Unit and i'd like to connect up my iPod.
    Is it possible? And if it is, what are my options?
    Any advice greatly appreciated.
    Thanks in advance,
    Andy
  2. Issac Hunt
    1,162
  3. 936ADL
    936ADL Member
    41
    Cheers for that link.
    Looks like it could be just the thing i'm looking for.
    Just one Q? which kit do i need? The website's not the best.
    Has anyone out there done a similar thing?
    Cheers again,
    Andy
  4. Issac Hunt
    1,162
    100 for Ipod alone, 300 if you want to play other generic USB/MP3 players as well, 400 if you want to keep your original Cd changer as well.
  5. 936ADL
    936ADL Member
    41
    Thanks for the reply.
    There appears to be two possible connections at the car end(20 pin ISO or 12 pin Quadlock). Is there a quick way to determine which one i need without actually taking the headunit out?
    Cheers,
    Andy
  6. hotglove
    hotglove New Member
    24
    Fitted one of these this week, car is 2003 A4 Cab with RNS D NavPlus (which has 20 pin connector)
    Fitting was a pain, but only because the installation instructions omitted to state that the hanging black cable on the replacement loom must be connected to the chassis of the radio/nav unit.
    Now that it is fitted it works fine, I chose the CDC retention and Bluetooth options.
    There was no easy way to obtain support from either Dension or the retailer.
    It's a shame that a good product got off to such a poor start, a decent helpline would have had it sorted in seconds.
    Ian
  7. rob1210
    rob1210 Member
    124
    I used the LiveChat function on the web site at ipodcarkitdirect.com and found them very helpful
  8. Issac Hunt
    1,162
    Probably the 20 pin ISO, what year is your car?
  9. 936ADL
    936ADL Member
    41
    Mine's a 53 plate car.
  10. 2low4u
    2low4u Active Member
    199
    42
    I have an S3 with symphony 1, is mine a 20 or 12 pin?
  11. 936ADL
    936ADL Member
    41
    If you check on www.ipodcarkitdirect.com there's info on there which tells you what connector each model has.
    Cheers,
    Andy
