Audi steering wheel
nemo2182 Oct 16, 2008
  1. nemo2182
    nemo2182 Member
    130
    Is it me or is the S steering wheel on B5's massive???I drive a Ford focus for work and it the wheel just seems more compact and easier to manage when turning. Is there a smaller vag unit that fits on orginal boss that is smaller???
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    may be cos the b5 is a bigger heavier car?
  3. nemo2182
    nemo2182 Member
    130
    Well this is an estate Focus...........
    Why does it need to be larger just cos its a big car?
  4. Siena
    Siena Active Member
    2,626
    The Focus may be a station wagon, but it's still lighter than even the smallest-engined A4 sedan - the 1,6.
    A larger steering wheel requires less effort to turn, even if the rack was non-assisted.
    Same principle with larger brake rotors vs smaller ones...
    Less effort, same result.
  5. auroan
    auroan Active Member
    1,669
    The normal non sport stearing wheel is a little less chunky, but still similar in diameter.
  6. nemo2182
    nemo2182 Member
    130
    ok fair point, the s4 is bit on the porky side, but if I wanted to get a smaller wheel, is there anything that will fit on without me having to change the boss kit??
  7. aragorn
    18,019
    716
    there is no "boss kit" on a standard steering wheel...
    The boss is integral to the wheel itself.
    You'd either have to buy a boss kit and a aftermarket wheel, or find a wheel from another model of audi/vw that fits, is smaller, and has the same airbag hookup
    A3/S3 ones might work? but i dont know if they're actually any smaller.
  8. Siena
    Siena Active Member
    2,626
    A3/S3 ones are the same diameter as B5 A4/S4.
  9. andybnwc
    andybnwc Member
    752
    I know i shouldnt but i have a isotta wheel with no airbag ,cause always been used to that kind of wheel and couldnt get used to the s4 one
  10. PaulJC84
    PaulJC84 Owner
    2,890
    13
    MRC fitted an R32 one to their S4. It is chunkier and looks slightly smaller.
  11. rasA4
    3,287
    119
    which wheel do you have a 4 or 3 spoke?
    i would much rather have a steering wheel with an airbag, having an aftermarket wheel you wont have an airbag and also you will have to deal with the airbag warning light.
    If you dont deal with the light and if you have any other airbags in the car they will not work until you have cleared the warning light.
  12. nemo2182
    nemo2182 Member
    130
  13. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,769
    31
    I remember a mate who used to have an E30 325i with this tiny Momo wheel. It was ridiculous as you could only either see the speedo or revcounter at certain wheel positions. And you were pretty much guessing what speed you were doing between about 60 and 90mph without dislocating your neck!
  14. andybnwc
    andybnwc Member
    752
    I had a e30 325 with a 320mm simoni ,i had no power steering! and i know what you mean about not seeing the speedo etc lol
