Audi Solid DRL Conversion
TheAnticitizen1 Sep 4, 2013
  1. TheAnticitizen1
    TheAnticitizen1 Member
    50
    Hi All,
    I've been trying to find out how Audi make their new DRL I currently have a set like this:
    I like the style of these lights but I would be much happier if they are a solid beam like this:
    So I would like to convert what I currently have to the new style but I can figure out how Audi work that bar? Does any one know the secret?
    I have found these for my car:
    But I think its too 'busy' if someone made one with just the top bar I would buy it straight away but top and bottem is too much! i don't want a mobile disco :p
  2. NME
    NME Member
    150
    19
    I understood it to be made by passing an extreme voltage through a gas, which excites it to produce the light emitted.
    That's why no one else can really make them look as good!
  3. Big Pumpa
    Big Pumpa Member
    135
    OEM all day mate!
    Jack_tdi, RedDejavu and sliced like this.
  4. NME
    NME Member
    150
    19
    There was a thread a while ago, where somebody was going to try and put the 8P3 DRL headlight inners into an 8P2 headlight housing.
    It created a bit of excitement, but it never happened. To be fair, you've got to have balls of steel to split open a perfectly good set of facelift headlights, and venture into the unknown.
    I know someone did it with a set of A4 facelift headlights, and used a set of aftermarket headlight housings from somewhere like ebay. The only drawback was that he had aftermarket HID lights rather than OEM Xenons, but he had OEM DRL's.
    I think those details are right, it's been a while since I read the thread.
    VWVortex.com - New Led A4 B8 Headlights on A3
  5. TheAnticitizen1
    50
    on your credit card I take it?
  6. TheAnticitizen1
    50
    Ahh thanks for the link I've split headlights before on my Saxo (first car) so I would'nt be too worried I was thinking perhapes using acrylic to try and diffuse the light as it passes through..
  7. Big Pumpa
    Big Pumpa Member
    135
    What's the price difference... £300ish?
  8. TheAnticitizen1
    50
  9. Big Pumpa
    Big Pumpa Member
    135
    Ah right, my bad... I thought you were just deciding between aftermarket and OEM LEDs! I'm doing the whole front end conversion for the lights at the mo too mate. Got the bonnet, front bumper, wings etc. Hasnt been cheap that's for sure!
  10. TheAnticitizen1
    50
    I wish I could afford it :( lol Too cut a long story short a uninsured driver drove into my car and I rather then claim on my insurance (I now have protected no claims) I paid cash for the repair, the aftermarket headlights are cheaper then the Audi official ones and make the car look a bit nicer :p I just wanted to see if I can change the DRL to look more OEM :p has anyone tried EL Wire for this?
  11. josh290
    josh290 New Member
    I've thought about this before and EL wire came to mind, however I imagine it might be difficult to get the wire extremely straight and positioned properly within the headlight its self.
    Found this online, it doesn't look to good IMO
  12. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    so basicly just a cold cathode light then? nothing secret or expensive there
  13. TheAnticitizen1
    50
    Well I was thinking I have a channel which the current L.E.D's are in but apparently EL isnt very bright in daylight
  14. NME
    NME Member
    150
    19
    Not being funny mate, but the effect we are after here is not the type of light you buy from Maplins to light up the inside of your PC case!
    There is imho a clear difference between other car manufacturers, and the clarity and brightness of the light from Audi's DRL's.
    Especially if you look at the 8V model - it is a clear, bright and defined light strip.
    I think the technology is more like a sodium lamp than a cold cathode.
  15. TDI140
    TDI140 Well-Known Member
    1,624
    174
    Get some xenons or do the facelift to the 8p3 front end i coukd have sold you my xenons if i had won a facelift on ebay on the weekend but lost it by £250 lol
  16. bailzey
    bailzey Member
    53
    I have the same headlights as the top ones, only problem is they seem to get condensation on the inside! Have you got the same problem? Don't mean to hijack your thread sorry!
  17. TheAnticitizen1
    50
    I do remember reading something in the booklet about condensation when I brought them but so far I have not had any trouble. I did recently drill a 10mm hole with an air filter in the rear cover for each headlight as I have LED dipped bulbs and they require a fan to cool them :)
  18. bailzey
    bailzey Member
    53
    Yeah I read that too, mine are pretty bad, really like the headlights but the condensation is ruining them! I suppose the fan will most definitely help, don't so much fancy putting fans on the back of them though, seems a bit pointless for me as I've just got standard H7's. Wonder if there is any fix for it hmm..
  19. TheAnticitizen1
    50
    sorry I meant that the fan is built into the LED bulbs I made a thread on the upgrade:http://www.audi-sport.net/vb/a3-s3-...5243-led-headlight-bulbs-alternative-hid.html
    Perhapes check the seal between the glass and the rear of the headlights?
  20. bailzey
    bailzey Member
    53
    yeah I had thought that but ripping them apart and re sealing is a ball ache! and I'm not a 100% sure what I would re seal them with too. I have a set of oem xenons that I've not fitted to the car although they are missing ballasts and the ballasts cost a fortune!
  21. boost-addict
    1,000
    39
    Tiger seal.
  22. murrayl
    murrayl New Member
    Sorry if in being a noob here... Only got my audi the other day (55 plate ) already want to upgrade the front end to the newer model. Can you not but the Bi-Xeon conversion kit and just buy the newer headlights with the DRL's I know it's not the same DRL's as the OP is talking about but would this work. Also if you want the newer front bumper do you need to do the bonnet and wings too?
  23. jphc
    jphc RS6 Dreamin'
    163
    9
    i found this on Reddit if you wanted to see those headlights fitted.
    I actually really like them....
  24. murrayl
    murrayl New Member
    They actually look quite nice
  25. TheAnticitizen1
    50
    They do look nice there but does anyone have a photo of them on? I would also like to see them at night! they have a top bar bottom bar plus 4 white L.E.D's I just think when its all on that would be too much..
  26. AudiMafia
    AudiMafia Member
    403
    13
  27. AudiMafia
    AudiMafia Member
    403
    13
    its much similar like this
  28. TheAnticitizen1
    50
    Thank you for the videos they do look nice powered on and I hear good things about Welldone!
    Does anyone on this forum have a set of these lights and can provide day/night images? or a review?
  29. AudiMafia
    AudiMafia Member
    403
    13
    No one that i have seen have done this mod, but you can be our first and provide all the infos we need :)
  30. TheAnticitizen1
    50
    Please can you provide me with a link to these on the Welldonehid website? I canne find them!
  31. TheAnticitizen1
    50
    I've ordered a set of the above! Will post pics when they are installed in about 2 weeks
    Jonathaan likes this.
  32. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Look forward to this, how much did they cost? And im guessing they came with the A38P HiD headlights aswell ? ?
  33. TheAnticitizen1
    50
    Well I paid £210 inc P&P & VAT from FK Tuning, I don't think these will include HID. When I searched on the Welldone website for the ones in the video I could only find it on the Spanish version so I'm guessing they would not be LHD and I could not get a confirmation if they included the HID kit sooooo I have signed up to the Welldone HID bulk order thread on this forum and will purchase HID's later :)
  34. TheAnticitizen1
    50
    Well the lights has arrived!
    They look pretty damn nice in person! After having a chat with my mate whom also happens to be my mechanic he has agreed to help me fit these tomorrow night (weather permitting) as he often works with Audi we think we can have these fitted within an hour!
    Its going to be a tight schedule I'm due to move house Monday so if the work isn't completed tomorrow night I'm afraid it won't happen until next weekend!
    I will post as soon as they are fitted!
  35. JS3
    JS3 Member VCDS Map User
    227
    They look good, much prefer the continuous LED look rather than individual LEDs.
    I think the lights are held in by 3 screws? And you can access them without having to remove the front bumper - but somebody may be along to correct me on that. I think the third screw requires an extra long torx bit to remove if you arent taking the bumper off.
    (Bumper off is much easier, but allow an hour to take it off properly IMO)
  36. J8TT X
    J8TT X Member
    360
    9
    Make sure you take pictures as your doing it, would like to see how its done.
  37. TheAnticitizen1
    50
    Yeah I have adjusted the lights without removing the bumper before but I think for a full install we will remove it to be on the safe side, its not a big job tbh but I'm gonna let my mate do it as he routinely does it for work it makes more sense!
    I will make sure to grab some photos of the work so you can see what has been done, I will also take some photos of the custom loom I made so the DRL is on whenever the ignition is on as I wasn't happy with the Vagcom one!
  38. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Nice update, look really good! cannot wait to see these fitted :rockwoot:
  39. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    * Also, you got a link to them from the FK website? *
  40. TheAnticitizen1
    50
    Sure :) Click Here for the chrome version and Click Here for the black version. I brought the black version also if you signup to their newsletter you get a discount off the final price.
