audi sat nav help
vorney Apr 10, 2014
  1. vorney
    vorney Member
    123
    Just upgraded my audi stereo to the rsn-e sat nav. Just a quick question can I use the sd drive for the sat nav, or do u have to use the disc
    Many thanks
  2. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I think it's possible but I never found one to put in mine, somebody like NHN or ash187 will know for sure, try to get the data and try it?
  3. hades-
    9,481
    646
    disk only as its dvd based
  4. vorney
    vorney Member
    123
    :sign_unfair:
  5. Inked
    Inked Takin it easy
    163
    35
    I used to run the Nav in my A4 off of an SD card, not sure whether other models can though.
  6. vorney
    vorney Member
    123
    Interesting. Did you buy the sd card off ebay or from audi. What type of unit was it?????
  7. Inked
    Inked Takin it easy
    163
    35
    Just a 16gb SD card bought from amazon. Copied the whole contents of the DVD across and it was recognised by the Nav with no problems. Was a 2011 A4 with tech pack low, don't know the model of the Nav I'm afraid.
  8. Mikemc
    1,024
    37
    But didn't audi actually sell SD cards with maps on them?
  9. vorney
    vorney Member
    123
    Might just have to try it for the sake of an sd card cheers
  10. Inked
    Inked Takin it easy
    163
    35
    It's worth a go, worked straight away for me. Literally just opened the contents of the DVD on my PC and copied the whole lot to the SD card
  11. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,698
    642
    If it RNS-E then it is disc only, been asked hundreds of time before and it always the same answer. Later model A4's (B8) with MMI could be ran off SD card.
    a6_chris likes this.
  12. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    As above, it'll not work!! SD on the rnse is for music only.
