Audi S8 Enhancement Detail
butler2.8i Sep 3, 2012
  1. butler2.8i
    butler2.8i Member
    184
    23
    Products and equipment used
    Uber microfiber towels
    Chemical guy’s woolly mammoth drying towel
    3m yellow pads 150mm 75 mm
    3m Green pads 15mm 75mm
    140 mm Glazing pads
    Halogen site lights
    Makita rotary polisher
    DA Polisher
    Scholl s17+
    Scholl s3 gold
    Prima Amigo
    Swissvax Best Of Show
    Carpro eraser
    3m masking tape
    Meguiars APC
    Costco microfibre towels
    Meguiars hyper dressing
    Valet pro citrus bling
    Bilt Hamber AutoWheels
    Valet Pro PH neutral Snowfoam
    Valet pro tyre dressing
    AMDetails AMbubbles
    Bilt Hamber clay bar
    Autosmart Tardis
    Various brushes
    Kranzle pressure washer
    Carpro Sheepskin wash mitt
    Carpro Dlux
    Noodle wash mitt
    Carpro Lambs wool wash mitt
    Poorboys microfibre clothes
    Uber buffing clothes
    Autobrite Snow foam gun
    Chemical guys Jetseal 109
    Autobrite Repel
    Auto Finesse Mecury Metal Polish
    00 grade wire wool
    Some photos of the car before I start
    The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
    The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed doing using the pressure washer.
    The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
    The arches where next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth. The engine bay was sprayed with APC and left do dwell before being given a tickle with a soft detailing brush before being rinsed with the pressure washer and dressed with Megs Hyper dressing.
  2. butler2.8i
    butler2.8i Member
    184
    23
    A few shots using my site lights I then taped the car up and went round with various yellow 3m pads and Scholl s17+ polish some panels required the use of S3 Gold on green 3m pads after polishing each panel was given a wipe down with carpro eraser after polishing to check finish and remove any polishing oils.
    I then went round the car and applied a coat of Prima Amigo using the DA and the lake county pad which was left before being buffed using Uber buffing towels.
  3. butler2.8i
    butler2.8i Member
    184
    23
    The car was given 2 coats of the Swissvax Best Of Show wax leaving wax to bond for 30min and approx 60min between each coat again buffed using Uber buffing towels.
    The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
    After this I cleaned the glass and gave them all 2 coats of Autobrite repel and also gave the arches coat of hyper dressing and dressed the tyres using the Valet pro tyre dressing. Alloys sealed using 2 coats of Chemical guys Jetseal 109
    Seats cleaned and fed with Furniture Clinic Kit
    Exhaust`s where cleaned up using Auto Finesse metal polish and 00 grade wire wool
    Some for the beading fans
    Finished engine bay shot
    Here`s a link to my facebook page
    http://www.facebook.com/NorthEastCarCareUK
  4. RYes3
    RYes3 Active Member Team Nardo Audi RS3
    919
    198
    43
    Wow, simply stunning!
  5. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi butler how long can you leave iron x on for ,and did you detail the car in one full day,or over a few days? Just trying to understand the whole detailing game,,cheers
  6. Artimus
    Artimus Shortback
    2,014
    483
    beautifully restored to 'as new' condition. :thumbsup:
  7. glasgowdubber
    glasgowdubber Active Member
    335
    62
    Amazing work, hats off. defo one of the shiniest cars I've ever saw lol!
  8. butler2.8i
    butler2.8i Member
    184
    23
    This car was done over a couple of days as they are a big old beast to work your way round, ironx is left for a few minutes to work its magic then rinsed and reapply if needed
  9. DALE_AVANT
    DALE_AVANT Member Team Brilliant Black Audi A4 Audi A3 Audi Avant Owner Group TDi
    618
    21
    Fantastic work, that's a lot of metal to work on!
  10. butler2.8i
    butler2.8i Member
    184
    23
    Cheers Matey
