audi s3 uprated fuel pump
crack5111 Sep 28, 2011
  1. crack5111
    crack5111 New Member
    is there an in tank replacement kit for the audi s3 (walbro255) etc as i have only found them for seat lcr's or do they fit?and whats the highest flowing (biggest) pump you can fit in tank?(highest horse power rating) cheers
  2. badger5
    9,471
    1,988
    Considered an inline supplementry pump to the S3's in tank?
    My ibiza racecar runs in tank S3 pump, which feeds a swirl pot, which in turn feeds 2 x 044 bosch pumps....
    Off load the S3 pump can deliver 3.3ltr/min (measured)
    If your in tank pump is ok, the inline may be a better option.. Some issue on high flow walbro's dropped in tank, can suffer pickup issues when on low fuel..
    What power you aiming for from your fuel system?
  3. Barks
    Barks Member
    337
    Hello I went for a DA-31 inline fuel pump on Bills advice and it just goes where the existing fuel filter is:-
    items in Driven 2 Automotive store on eBay!
    I will be fitting it this weekend,
    Bills I gather the small end is the outlet???
  4. <tuffty/>
    21,143
    3,832
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Where did you put the filter tuffty?
  6. badger5
    9,471
    1,988
    yep, M12 is outlet, M18 is inlet
  7. badger5
    9,471
    1,988
    We use an ibiza cupra filter (smaller) mounted in engine bay, spliced into the rubber hose feed to the fuel line.
    8mm ends which fit the hose nice with good hose clamps.
    Supporting the filter against the power steering resevoir (cable tie or bracket)
  8. s3dave
    10,110
    736
    Cheers Bill, then its just a case of getting the power down to the pump,(presume cut into original fuel pump supply) is the load ok for 2 pumps running ?
  9. crack5111
    well i was considering maybe even an uprated in tank pump plus an inline aswell but if theres some issues with the in tanks then maybe the best option is like you say to feed an inline pump from the standard in tank one?as far as i know my fuel pump is ok but i haven't done any tests to see how well its working.
    where can you get the ends for the da 31 as pistured so the the fuel filter pipes clip on securely?can you buy a kit?
    when i eventually get together everything i need i am aiming for 5-600hp
  10. badger5
    9,471
    1,988
    Not had any issue in tapping off the in tank pumps supply to feed the inline pumps.
    decent gauge wire feed to them and fuses seem happy.
  11. badger5
    9,471
    1,988
  12. <tuffty/>
    21,143
    3,832
    As Bill said... Ibiza filter...
  13. Barks
    Barks Member
    337
    Hello Tuffty where did you get the OE fuel connectors?? Makes it look nice!!
  14. <tuffty/>
    21,143
    3,832
  15. Barks
    Barks Member
    337
  16. Barks
    Barks Member
    337
    Got it!, Cheers
  17. Barks
    Barks Member
    337
    Bill,
    Just to let you know, I ended up putting a under cut on the threads on the adapters to get them to sit flat with one washer as there is no counter bore on the fuel pump.
    Dave
  18. <tuffty/>
    21,143
    3,832
    Ah... with yah....
    Bill had some of his old Ibiza fuel line kicking around so I robbed them off those... I have looked everywhere tbh to find them separately but think if I needed them again I would either go to a breakers and get the from a car or stump up and buy appropriate hoses from VAG...
  19. Barks
    Barks Member
    337
    Hary Bucklands scrap yard it is then!! Gives it the professional finish!!
  20. badger5
    9,471
    1,988
    thats not th emod which was needed. the washers would sit flat to the pumps face... their overall length needed shortening thats all
  21. darren t
    darren t Member
    568
    hi bill I bought some of your inline fuel pump adapters through eBay 1 side is leaking do I need too change the copper washer remove?
    or is it just a matter of nipping the inlet side up,only ask as I have small leak after priming think it just needs tightening but its dark now so will check tmorrow
  22. badger5
    9,471
    1,988
    nip it up, and or use sealant on the threads. only copper washers. you cant have done it up tight enough
  23. benashley
    benashley Member
    59
    Is there a reason for not just putting the additional pump in the engine bay where you relocate the filter to?
  24. Gary_808
    Gary_808 Member
    166
    It's always nice to have a filter after the pump, just incase it start to or fails.
  25. benashley
    benashley Member
    59
    Good point I didn't think if that
