Audi S3 Problem
spliffey Jan 18, 2012
  1. spliffey
    spliffey Member
    78
    Hi there basically my car was overheating as temp was going upto 110 but if i turned car on and off it would to back to 90 instantly, so i got the thermostat changed thinking it was this, but now its worse it gets upto 120 and hardly cools downs :(
    Any ideas guys??
    Thanks in advance
  2. S3featesV9
    S3featesV9 Active Member
    1,032
    12
  3. <tuffty/>
    21,688
    4,118
    Thermostat issues would mean the temp would nopt get hot... over heating is norm alloy a failed water pump...
    CTS failure (in my experience) doesn't over read... if you are seeing 110 deg then I suspect its the pump...
  4. spliffey
    spliffey Member
    78
    Thanks guys, if it was sensor would it read on vagcom??
    Just took out now it gets to 110 very quick and then 120 and stays on there? Could it be head gasket possibly?
  5. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
    Tuffty says...
    if its at 120° i wouldn't take it out for a test drive or quick spin
  6. chippie
    chippie Member
    91
    Does sound like it could be the water pump, do you know if its been changed as they do tend to break the fins off, I wouldn't be driving far if this is the case as you could do more damaged with it overheating
  7. spliffey
    spliffey Member
    78
    I don't know mate, any ways to find out? I'm not really a mechanical person :p
  8. <tuffty/>
    21,688
    4,118
    Not easily... do you know if the cam belt has been done and if the water pump was changed at the same time?
  9. spliffey
    spliffey Member
    78
    Yeah Cambelts been done, cant find receipts for water pump so I'm guessing no...
  10. Ashley g
    Ashley g Member
    171
    Almost guaranteed to be the water pump!
  11. <tuffty/>
    21,688
    4,118
    Aye... my vote is pump... normally done with the cambelt change as its the same amount of work to get too..
  12. chippie
    chippie Member
    91
    When the engine is cold you could take the top off where the antifreeze goes in and get someone to rev the engine, have a look and see if there is any movement in the water, also see if the pipes to the radiator get hot, but from what you say about getting hot very quick it does sound like the water pump, it should always be changed same time as cambelt, I did mine after only 50k and it looked rough
  13. spliffey
    spliffey Member
    78
    Il have a look when it's not so cold outside, I also wanted to add that car blows cold air from heaters....
  14. Alex C
    3,294
    372
    that'll be because your water isn't being circulated around the engine because of your broken pump. Therefore the heater matrix never gets hot and therefore the air that gets blown over it never gets hot??
  15. <tuffty/>
    21,688
    4,118
    Still voting for water pump ;P
  16. spliffey
    spliffey Member
    78
    Haha yep I trust all you s3 owners that it's the water pump, I'm getting it done tomorrow so il let you all know, also Alex it might get slightly warm sometimes when temp will hit 110 but then will cool back down :(
  17. spliffey
    spliffey Member
    78
    Thanks guys, turns out it was the water pump
    Thanks for your help!!!
  18. <tuffty/>
    21,688
    4,118
    What do I win? LOL
    Bad times dude but at least you know now :)
  19. I know this is a silly question, but have you checked that the engine is actually that hot? and is fan kicking in etc?
    Ive had a lot of problems with: Fuel gauge, rev counter, speedo, lcd screen and temp gauge (same sorta problem as yours). Its all to do with a faulty Instrument Cluster.
  20. Alex C
    3,294
    372
    silly? as in water pump was suggested, checked and found to be the fault and problem solved? that sort of silly? :p
