  1. goodbuzzman1
    goodbuzzman1 Active Member
    546
    58
    Sowhile trying to sort some running issues, i discovered that when i unplug my MAF the car runs waaaaaay better. I ordered a new one and plugged it in and it runs worse than ever!!
    Is there something i need to do after i plug the new one in? do i need to do a throttle body reset? and if so, how do i go about it
  2. <tuffty/>
    21,874
    4,201
  3. epox
    epox Active Member
    774
    74
    Did you get a Bosch Maf from tps? As this is a must don't use eBay or eurocarparts as they are ****.
    Mark
  4. goodbuzzman1
    546
    58
    hmmm maybe thats where i went wrong as it isnt a bosch one..
  5. <tuffty/>
    21,874
    4,201
    As long as its a Bosch one then you should be fine... I have used Bosch sensors from GSF and ECP as well as TPS and all run fine... non Bosch ones as already said are actual rubbish...
  6. <tuffty/>
    21,874
    4,201
    ...but scan for fault codes all the same.. preferably using VCDS
  7. Freeman_1986
    Freeman_1986 Member
    169
    21
    I've had 2 Bosch ones from ECP. Both were ****, so I just have it unplugged now. It may use a bit more fuel that way, but runs better and CBA with the hassle....
  8. <tuffty/>
    21,874
    4,201
    Have heard of rouge ones from ECP... generally get mine from GSF to be fair as ECP never seem to have stock... my current MAF sensor is from GSF..
  9. LynxE
    LynxE Member
    104
    14
    While you're on the subject...
    How do I get the MAF out the holder? I thought the 2 screws were security torx but I've tried a few from T20 to T30 I think but they won't quite fit in. Are they Torx?
  10. <tuffty/>
    21,874
    4,201
    5 point security torx...
  11. goodbuzzman1
    546
    58
    i tend to just dremel a slot in to them and use a flat head screwdriver to remove
  12. LynxE
    LynxE Member
    104
    14
    hmm sounds like Torx bits come in differing point counts then
  13. <tuffty/>
    21,874
    4,201
  14. LynxE
    LynxE Member
    104
    14
    Thanks. Can go back to cleaning my MAF this weekend
