Audi S3 horn??
Lloydie22 Nov 17, 2013
  1. Lloydie22
    Lloydie22 Member
    62
    9
    Hi guys, somebody cut me up earlier so i beeped them and nearly laughed at how pitiful and poor sounding the horn is (2009 s3)
    Can anyone advise of where i could get a better horn from? Would an A5 horn fit on the S3 for example?
    Cheers,
    Lloyd.
  2. NHN
    29,284
    1,695
    The 2 oem stock horns are perfectly ok on the 8P mate, unless yours are faulty, best to compare with another 8P owner of 09 facelift onwards, as they share the same part numbers, as earlier cars were different, being on either side of the car, whereas facelift 09 are on top of eachother in the fog area drivers side.
  3. Lloydie22
    Lloydie22 Member
    62
    9
    Okay thanks Nigel. It was actually quiet embarrasing. Its just sounds so weak. I suppose you can say a horn is a horn but i just wonderd if i can just change it to a slightly better one. Like the one on my S5.
  4. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    571
    Totally agree here... Moved from my a3 to s3 and the s3 horn is soooo gay!
    Jameze, autolatry and Lloydie22 like this.
  5. Lloydie22
    Lloydie22 Member
    62
    9
    Haha tell me about it! Whats the A3 horn like then? Abit more muscular? Lol
  6. S3_Jacko
    1,734
    571
    Yeah a lot more deeper... The s3 horn imo is more high pitched... Maybe its an audi road rage deterrant, cause most folk would be too embarrassed to press that in rage haha
    Lloydie22 likes this.
  7. mjr901
    mjr901 Parts Manager - (Main Dealer) Gold Supporter Audi S3 Audi Main Dealer
    3,589
    1,055
    When i had my 09 S3 I had the horns fail twice in 3 months.
    First low tone went, was replaced, then high went shortly after. When not paired with one another, utter embarrassment when pushing the horn!!
    So the chances are one of yours has packed up, not that expensive and not difficult to replace.
    Probably full of water/moisture, being low behind the fog grill.
    I fitted 3 horns to my MG, MUCH better! :rock:
    + as NHN says, the horns are perfectly loud, very german, more than adequate, if you think otherwise, they're definitely broken.
    + MY09 S3 horn(mounted in fog, next to each other) are just the same sound/noise as MY12 S3 currently, and mounted in the same place.
  8. S3_Jacko
    1,734
    571
    Maybe my low end 1 has packed in... I'll be taking my bumper off through the week and i'll give them a look
  9. Artimus
    Artimus Shortback
    2,005
    476
    A few weeks ago mine went squeaky for two days, then returned to normal on its own. it may have got wet when I washed it, then dried out and fixed itself. I'm not sure but it hasn't failed since. :uhm:
  10. larsmate
    larsmate Member
    121
    My low pitched went kaput while my S3 was under warranty. Mechanic said it was a common problem as the horns faced forward and filled up with water and ****. I got two new ones which he said he mounted facing backwards. They are now plenty loud enough.
  11. Lloydie22
    Lloydie22 Member
    62
    9
    Okay it looks like it isnt just me then!
    Can anybody send me a link for one that will fit my 09 S3 please?
    Would very much appreciate that
  12. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    hahah I read this as S3 giving me the horn....I was going to say...me 2!!!
    sorry it is Monday
  13. Lloydie22
    Lloydie22 Member
    62
    9
    No worries mate. I've just bought one off of ebay so lets see how it improves afterwards.
  14. Wicked666
    Wicked666 Active Member
    584
    35
    Don't think i've used my S3 horn since having the car. Will try it later.
  15. Lloydie22
    Lloydie22 Member
    62
    9
    Okay let me know if its as queer sounding as mine!
  16. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,140
    374
    I had a stebel on my last car sounds like this in the video, people really jumped and moved ;) I still have it but it will be going on my A3 when i cba.
    Stebel Nautilus horn - YouTube
  17. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    548
    98
    does it take much to fit this stebel nautilus?? I'd love one of these :)
  18. LEE69
    2,140
    374
    Needs to be fitted with a relay due to the amps it draws, So a positive direct from the battery, good solid earth then the standard horns triggers the relay, loads of wiring diagrams about
  19. S3_Jacko
    1,734
    571
    Anybody considered the dixie horn from the general lee? haha
  20. Lloydie22
    Lloydie22 Member
    62
    9
    Horn arrived today from ebay. Do i have to remove my bumber to allow me to change the horn? Can't see it from looking into the engine bay!? Cheers,
  21. mjr901
    3,589
    1,055
    As you look at the car from the front, tug hard on left fog grill. There's a nice gap to pull on the fog grill plastic, you'll see once removed.
    Bumper stays on I believe, fog needs removing though I think. it's been a while.
  22. Lloydie22
    Lloydie22 Member
    62
    9
    Cheers, appreciate that. I'll give it a go tomo in the light :)
