Audi s3 FUEL Smell ??
S3kbv Mar 9, 2013
  1. S3kbv
    S3kbv New Member
    Hi everybody I have Owned my Audi S3 8L for a just under 2 months and running sweet I noticed after buying it there was a smell of fuel I didn't think much of it and it was due a service anyway
    so I had it serviced new fuel filter new pollen filter new spark plugs oil change and filter new abs sensor for front, also auxiliary belt
    all this work was sorted and done on Thursday
    Friday, I drove from wolverhampton to Northampton and on my way back fuel smell turned up again while sitting on the amazing m6 traffic , any one have any idea of what it could be?
    Only seems to come when stopped or local driving.
    Installed to the car is a forodge 007 re-circulating dump valve silenced
    And a AMD remap to 260bhp
    just n case this would corse it :-S
    Thank you for reading my thread
  2. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    Could be a dodgy map....... I.e they have just whacked the boost and fuel up so its over - fueling when on tick over or when your not thrashing it. Though I would think the ecu would be able to accommodate this for all conditions..... :-s
    Have you noticed a poor return on mpg? Have you got access to vcds to scan it? Puddle of fuel when you park it lol? Engine light on?
    Sean
  3. S3kbv
    S3kbv New Member
    To be honest it's never there on tick over as I have tried leavening it running on my drive to see if it smell comes and it don't , but after a about 10 miles and stopping at a set of lights it starts coming but it seems to be come through the heater system if i turn heating off smell disappears :-S
    no fuel on floor or leaks
    well after service the mpg has gone a lot better but still poor then again I done 135 miles on £30 @ 1.38per litre
    No engine management lights
    when a computer is plugged into it it has no faults or fault codes if that's what you mean by vcds
  4. s33nyboy12
    1,488
    203
    Has someone fitted a catch can and vented it to atmosphere near the top end of the engine bay? Pcv simplify search the forum
    sean
  5. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Agreed, I think this is most likey.
  6. s33nyboy12
    1,488
    203
  7. markyR
    markyR Member
    118
    I had a faint smell of fuel from my engine bay the other week, not inside the cabin though. it turned out to be the pipe that comes from the carbon canister by the coolant bottle had rubbed through, I cut and joined the pipe back together, all ok now. I would also check the fpr hose, injector seals and smell round the fuel cap as may be a dodgy seal.
  8. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Check the PCV tubes, rocker cover breather, crank breather, I had a petrol smell when one of my breathers was split, didn't find it was split until I had pulled all the tubes out.
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    ^^This is common ^^
  10. Tooks
    Tooks Active Member
    753
    30
    Sure is, a split pipe from the carbon canister was the cause of my fuel smell too.
  11. losing it.
    losing it. Member
    76
    anyone know what the triangle shape box is and what it does, which is connected to the carbon canister mine is in pieces lol and pipe split too
  12. <tuffty/>
    21,583
    4,053
    If you mean the plastic bit where all the fuel lines are connecting near the brake fluid reservoir then its not a box as such more a bit of trim to locate all the fuel pipes for accessibility
    There is a pipe (if its the one I think you mean) coming off the charcoal filter and connects to a pipe coming out of this 'triangle'... this is the tank vent.... mine split and I replaced it with 6mm silicon vac hose
  13. losing it.
    losing it. Member
    76
    yea mate that's the one. I managed to cut both ends off that pipe and its still usable just a pig to put back on i had to heat the pipe up with a lighter away from the car.
    Thanks for the info man.
  14. s3mad_dude
    s3mad_dude Noggies ruuuule!
    614
    79
    +1 I had this and the smell would only come in when stationary in traffic - split breather pipe.
