Audi S3 Fog lights conversion
Ash B Oct 1, 2010
  1. Ash B
    Ash B Well-Known Member
    5,831
    85
    Hi guys
    I'm just wondering if any one can help me out. I'm looking to connect up the fog lights before ADI. I did have the part numbers saved in my emails for the wires, connectors and headlight/fog switch but now unable to find them now. Can any one supply part numbers that are needed please. Also would either of these switches be ok to use, most likely going to go for the older one. As its local and cheap at the moment...
    AUDI A3 HEADLIGHT SWITCH - eBay Mobile (item 140458685539 03/10/2010 21:31:42)
    2009 Audi A3 New Style Headlight Switch DRL S3 TT 8P - eBay Mobile (item 250704670533 31/10/2010 00:03:27)
    If the links dont work item numbers on ebay are 140458685539 or 250704670533
    Any help would be greatly appreciated
    Ashley
  2. mike foster
    3,967
    Both switches are for cars with auto lights (daylight and leaving/coming home )
    The cheaper one may be local but if it came off a 2006 car how come he's got the box ?!!!!!
    Feedback low at 91%
  3. Ash B
    5,831
    85
    Any one able to help? Just need the part numbers for the wires, connectors and a switch. And what ever else is needed to get the fog lights working. I'll ask some one local to sort out toe vag side.
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you only need one with just the foglights only, if you ordered the switch thats fitted to my a3 you should be sweet
  5. mike foster
    3,967
    What year is your car ?
  6. Ash B
    5,831
    85
    Cheers Phil, think i'll just buy it new from Audi easier.
    54reg Mike
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    thats what i meant ill give you my chassis number so that they get the right one, you werent actually getting my switch! i nedz it
  8. Ash B
    5,831
    85
    Aww cheers :) Sorry im half a sleep after two late nights and early starts lol. Pm me it when you can.
  9. mike foster
    3,967
    Sorry for delay - been looking for wiring harness ! It looks like the harness is already there for the foglight and just needs the connectors.
    Switch no. 8P2 941 531 L (5PR Black ) This switch is for sidelights, headlights and range control, front fogs and rear fogs.
    Connectors 3D0 941 165A
    Hope this helps.
  10. Ash B
    5,831
    85
    Thank you very much Mike :)
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    bingo thats the one
  12. Ash B
    5,831
    85
    Cheers for your help aswell Phill. Are you gonna be able to make ADI now?
  13. PH1L
    PH1L Gievf Buckets
    3,851
    40
    no bother mate, i wont be making it there car will probably be ready but id like some hitory with the car before i take it any distance, im presuming youve seen the pics since i got the car back?
  14. A3-8PA
    A3-8PA Member
    107
    Hi Guys, thinking of retro fitting front fog lights on my audi a3 - 2008 as I got only rear ones. I know I have to buy the following
    Grills
    Fog Lights
    Switch (8P2 941 531 B)
    Can somebody guide me like what else (like wire harness, relay, etc) I need to make it working. Do I need a specialist in VACOM coding as well?
