Audi S3 Engine troubles...
ekimyag Mar 27, 2010
  1. ekimyag
    ekimyag New Member
    Hi Guys,
    First time post here, any help is very much appreciated.
    I am hoping some one could help me out with something. I have sezied up S3 and have been looking into options for getting it running again.
    I have been offered a lower mileage AUM engine from a TT, the code for the current engine is APY, is this even possible? Could anyone tell me if it would cause any problems etc?
    Thanks for any help!
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,232
    2,054
  3. <tuffty/>
    21,689
    4,119
    AUM is a 150ps TT engine. The engine itself will fit but you will have to use your turbo/mani's etc. You will also need to change the cam chain tensioner as the APY is not VVT while the AUM is.
    Depending on what is damaged on your APY you could just use the block from the AUM and bolt your APY head on...
    It should be noted that the AUM appears to have the 19mm gudgeon pins where as the APY has 20mm.... 20mm is stronger...
    Check this out for more info in looking for a suitable donor
    http://www.audi-sport.net/vb/showthread.php?74563-1-8T-Info-Sheet
  4. ekimyag
    ekimyag New Member
    Cool thanks.
    Would I need a remap if I just used the block and used the excisting Turbo and mani etc? If the AUM is 150ps and the APY is 210. Will that not cause problems?
    Thanks again
  5. <tuffty/>
    21,689
    4,119
    No, what you are replacing is purely mechanical.... the power of an engine (in this case the APY vs AUM) is governed by ancillary components such as the turbo, injectors etc... as long as you just use the block then there will be no probs...
    What year is the TT the engine is coming out of?
  6. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Correct me if im wrong but they dont do a 150ps TT, only 180 (KO3s turbo) and 210 - 225 (KO4 turbo)
  7. DavidW
    DavidW Member
    211
    I thought they did a 150bhp 2wd one?
  8. S3 Nattie
    1,599
    I think the 2wd ones are 180bhp, same as a A3 and Golf facelift 1.8t
  9. ekimyag
    ekimyag New Member
    would the fact the turbos are different not cause issues then? I understand the engine Lump just being purely mechanical. But if the AUM is used to getting lower power turbo?
  10. gcs3
    gcs3 New Member
    25
    a3 and golf 1.8T are 150 bhp. quattro a3 and anniverary golf are 180. there was a 150 bhp tt i think
