audi s3 EML
m.dub Apr 6, 2010
  1. m.dub
    m.dub New Member
    Ok just had the EML come on, so took the car to a friend with a generic OBD reader and it came up with the codes
    P0035 (Turbo/Sup wastegate control circuit high)
    P0135 (02 sensor heater circuit malfunction) bank 1 sensor 1
    The car runs fine and boosts as it should.
    Does anyone have an idea as to why these codes popped up? Before i take it in for further investigation?
  2. Essflee
    Essflee Well-Known Member
    2,144
    67
    Ross-tech.com
    Check out this site, will give you the fault codes, possible syptoms, causes and repairs...
  3. m.dub
    m.dub New Member
    still cant fined any info on this, just really want to know what it means before i get my pants pulled down
    gettin it sorted.
    cheers
  4. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,543
    1,459
    P0135 (02 sensor heater circuit malfunction) bank 1 sensor 1- is the pre-cat lambda sensor, so its the one located on the downpipe. The error is referring to the heating element of the sensor. The issue could be bad wiring, so checking that might be your first port of call. When I had the issue, I just replaced it. It's 30 quid for the OEM spec BOSCH part from ebay (make sure it has the correct plug for your car). More details: http://www.obd-codes.com/p0135
    As far as the other code goes - I don't know, sorry
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    P0035 (Turbo/Sup wastegate control circuit high) check wiring on n75 valve
