Audi S3 drop on springs advice
AntonTDI Jan 6, 2013
  1. AntonTDI
    AntonTDI Member
    44
    Looking to drop my S3, lowest I could go without rubbing and rolling arches etc... I want a even gap front and back as standard the fronts sit a little higher, I would like 50mm front 40 back to get this... Do you guys agree and if so what springs are the best? Bearing in minds it's 4wd etc... It's got rotars on...
  2. NHN
    29,596
    1,782
    Give Damian@dpm a shout, he's the man for suspension systems, top bloke.
  3. br20vt
    br20vt Active Member
    199
    56
    Im sure the H&R 25mm's are the lowest springs available for the 8P?
    Thats what im using at the moment, looks ok on the standard wheels and sits pretty much evenly. I wish id have just got coilovers to start with :think:
  4. AntonTDI
    AntonTDI Member
    44
    Thanks guys, you got a pic of your car on the 25mms mate?
  5. br20vt
    199
    56
    Havent got any pictures since fitting them really, theres quite a few in 'The Rimz thread' in this section though
  6. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,514
    658
    25mm H&R are the way to go. Excellent spring. Been in my car 3.5 years with no issues what so ever, no rubbing on either my 18" standards or BBS CH 19's.
  7. Reload
    Reload Bird is the Word!
    367
    50
    I'm on 25mm KW also with no issues. Now anyway, bit of creaking from front offside when first fitted but that went away after a couple of hundred miles bedding in, looks pretty decent with the spacers too:)
    GNJ_Motorsport likes this.
  8. JS3
    JS3 Member VCDS Map User
    227
    Does anybody have a step-by-step, with photos!, of how to replace OEM springs with lowered springs on an S3? Thanks.
  9. S3 syc
    S3 syc Active Member
    157
    30
    im the same wish id have just gone for coilovers to start with,good springs the h&r ones but if your wanting a really noticeable drop there not really the way forward as the only do 25mm. mine will be available soon when i fit my coilovers if your interested done around 600miles on them.
  10. Jonse
    Jonse Active Member
    449
    49
    How much does it cost to have springs fitted?
  11. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    My old S3 on H&Rs (25mm)
  12. Smiffi
    Smiffi Member
    156
    Hey guys, do the H&R springs affect the ride much? Do they make it a lot firmer?
  13. DickosS3
    DickosS3 Member
    30
    I got h&r on mine. Totally transform the ride. May I also suggest the 11mm forge spacers to finish off.
  14. Smiffi
    Smiffi Member
    156
    When you say transform, I take it you mean for the better? I don't mind the ride in mine as it is.
    Paul, those pics look great. Does your car have H&R springs all round or just on the front to even the arch gaps up?
  15. DJ-S3
    DJ-S3 Active Member
    690
    43
    I also like how my original suspension is. But not too keen on the huge gap from tyre to arch. Is it possible to keep the suspension with the same feel but lowered? I've been looking at coilovers but from past experience there very hard. I've also been thinking getting dampeners and springs separate but not sure how I'd know what it'd feel like before I buy...
  16. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    H&Rs alround.
    The car drove much tighter, turn in was better and roll was greatly reduced.
    Bit bouncy on some fast A roads but I worthwhile mod IMO.
    Dont forget to get a full geo set up. I was told it was uneccessary and it cost 2 front tyres after about 3K miles.
    I paid £180 for the srings from Awesome.
    £100 fitting.
    £40 geo set up.
    Paul
  17. DickosS3
    DickosS3 Member
    30
    I find the hrs to be quite hard but not as hard as coilovers. Defo a well worth mod. Got the springs off Graeme at www.gnjmotorsport.co.UK and he did me a great deal for springs. Spacers. Wheel bolts and lockers. Much recommended.
  18. Acheron
    Acheron Active Member
    271
    30
    As an alternative this is mine on Eibachs Sportlines (only comes with 20mm front springs to remedy the reverse rake from stock):
