Audi S3 cylinder head problems!! 2001 AMK
stoneys3 Oct 25, 2010
  1. stoneys3
    stoneys3 Member
    118
    hi,
    As discussed on a previous thread i was doing my head gasket etc. I have now removed it at the weekend and the water ports are mega corroded!:( not a happy chap! It will not skim out so my only thoughts are getting it welded buy a pro and then skim it..(if this is possible?) or hunt for a another head!
    any ideas/help greatly appreciated
    ash
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    126
    For piece of mind, slap another head on IMO.
    Any VVT 1.8T engine's head should do. Because it's from the S3, the head will cost more dosh than say an AMK head from a MK4 Golf. Same thing though, and will work fine AFAIK.
  3. Welly
    10,696
    126
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,244
    349
  5. Welly
    10,696
    126
  6. Alex C
    3,244
    349
    yeah thats what i thought, i would if i had the ability/money to do it all myself
  7. <tuffty/>
    20,797
    3,662
    which am the bestest!... ;P
  8. Welly
    10,696
    126
    Word...
  9. Alex C
    3,244
    349
    yep i know, but i dont know if your going from normal small ports to large port if you need to get new intake and exhaust manifolds which the OP might not want the hassle off if he just wants it fixed... but it would be awesome. It is saved in my watch list on ebay along with another large port head i have found :)
  10. stoneys3
    stoneys3 Member
    118
    hmmmm its says it comes with valves and the lot..but its not shown in the pictures. will my bottom end cope with the big ports ect? very very tempted to buy this!
  11. Alex C
    3,244
    349
    will it need to be remapped going to a large port head?
  12. Welly
    10,696
    126
    Everything bolts on the same. You will need a large port inlet manifold gasket though. I used to have an AGU engined A3, so if you do buy this, I'll PM you the reg number so you can get the right gasket.
    Both Tuffty and I are running large port heads on standard 1.8T blocks (except for the forged roads, and mine is in fact a complete AGU engine).
    They fit, they work. End of the day, it's just another 1.8T head.
    EDIT: Adding to this, if you have an AMK engine, you will need to swap your VVT cam chain tensioner over. None of the large port engines came with VVT. So it will not be quite bolt on and go.
  13. Welly
    10,696
    126
    Nope. It's just a head. It will just flow better.
  14. <tuffty/>
    20,797
    3,662
    Lot of money though.... can get large port heads cheaper than that but would still recommend getting the exhaust guides done...
    Not a prob with manifolds... small port stuff from the AMK will bolt straight on... One other thing that should be mentioned is that whatever 20v turbo head you end up with, if it hasn't got VVT you will need to transfer that across... I transferred my followers, cams and VVT over from my old AMK head to the AEB large port I now have....
    I do not know if the non turbo 20v are suitable though and early 20v heads may have a bit that needs machining off where the tensioner pully bolts up due to an earlier design...
    Make sure any head you get has the cam caps that came with that head else you will have issues as they are line bored to the individual heads and don't worry if the head you get has a SAI port as that can be blocked... AMK S3's don't have SAI..
  15. stoneys3
    stoneys3 Member
    118
    i really wanted a bolt on and go jobby.. but if i can gaim a little from the larger ports ect i mite just go for that and change my stuff over. SAI? whats this, i'm being thick.
    ash
  16. stoneys3
    stoneys3 Member
    118
    another thing there is a £100 surcharge on that head but i don't think they will except mine as it's foobard!
    ash
  17. Alex C
    3,244
    349
    sai is secondary air injection. You wont have it on your AMK, but the AGU does have it which is why you will have to blank it
  18. stoneys3
    stoneys3 Member
    118
    oh rite cheers. do you think its worth doing in my situation?
  19. Alex C
    3,244
    349
    well if i was in your shoes where i had to go out and buy a new head anyway then yeah i would very very strongly consider it. As it is, my AMK head is fine, yet i still have the large port head saved in my ebay favourites.
  20. Alex C
    3,244
    349
    what sort of price are you looking at for a non ported, small port head?
  21. stoneys3
    stoneys3 Member
    118
    duno really cheap as possible really and preferably skimmed and pressure tested. not sure to be honest alot less than the £500 one on ebay as i mite aswell have that othewise.
  22. Sandip
    2,438
    90
    Another AMK head dies:sorry:
    What's the mileage on yours stoney?
  23. Andrew@A.L.D
    3,872
    608
  24. stoneys3
    stoneys3 Member
    118
    68000. i brought it bumped, so dint really know wat it was like until it turned up, its now had a full respray and now sorting the engine out lol not drove it properly yet. some nob-head must have kept filling it up with water and ignoring the problems. ohh and the turbo is ******!! brought a real pup! but once i sort these few problems should be a minter.
  25. stoneys3
    stoneys3 Member
    118
    what mine?? how? who? how much?
  26. S3 Andy
    S3 Andy Member
    69
    Not sure if this is allowed - but I have an APY head for sale at the moment, have a look in the classifieds.
    Removed from the car on 88k miles (went to an AGU head).
    Comes with everything pictured, but you'd have to swap over your cams, chain + tensioner and blank off the SIA.
    APY head - Audi-Sport.net Classifieds
    Edit: not sure if you'd need the old style coilpacks aswell with this? I had to as the 'bolt down' ones this uses wouldnt fit the my new head... Also have these 4 for sale aswell...
  27. Alex C
    3,244
    349
    did you mean save some pennies?
  28. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    well ill be saving that guy on ebay and getting a large port head when got some dola looks good
  29. Welly
    10,696
    126
    ^^ I saw it as well before it went. lol
  30. Alex C
    3,244
    349
    lol
  31. stoneys3
    stoneys3 Member
    118
    spoke to the guy who owns the shop, very handy and good to talk too.
  32. Andrew@A.L.D
    3,872
    608
    Yes yours, a good welder and good machinist, me, depends on the damage
  33. stoneys3
    stoneys3 Member
    118
    a bloke has quoted me a good price to repair mine, i will get some pics up tomorrow.
    anyone now of a turbo recondition place as mine has play in and out?
  34. Welly
    10,696
    126
  35. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  36. stoneys3
    stoneys3 Member
    118
    cheers guys i wil give them a try tomorrow. cylinder head,cambelt, waterpump and turbo! hopefully after this i shud be problem free lol.
  37. stoneys3
    stoneys3 Member
    118
    What car does the apt head come off??
  38. Alex C
    3,244
    349
    ...APY?
    Its the early S3 engine, the one before AMK i think
    if you do mean apt, then i have no idea
  39. stoneys3
    stoneys3 Member
    118
    ye am pretty sure its apt?? al av another look tomorrow. this is what i got bak as my reconditioned head today.
  40. tompearson
    tompearson It's all in bits
    219
    It's from a Passat. Non turbo 1.8 I think.
