Audi S3 after remap
Effect Apr 27, 2008
  1. Effect
    Effect Member
    469
    Since my car has been remapped I occasionally get a flat spot about 5000RPM
    anyone know what this could be ?
    Regards
    James
  2. Aky
    Aky Aky
    1,512
    Which remap did you go for in the end? Occasionally mine does it but re-apply the gas and it sorts itself out. I think this is a bit of a common issue.
  3. vanilla_ice
    vanilla_ice Active Member
    713
    Not the TIP collapsing?
    ICE
  4. jojo
    28,929
    3,583
    Consider your MAF, is it just a flat spot at the same revs everytime you go past, or a stutter like power delivery after 5k revs?
  5. Effect
    Effect Member
    469
    it doesnt happen every time.
    It has happened a couple of times at 5k.
    For a second or so the power seems to drop off then come back again.
    It was a custom code done by JBS.
  6. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Agree, check out Forges site that has a vid on this issue.
  7. Aky
    Aky Aky
    1,512
    Its not the TIP collapsing as I've got a Forge TIP and it still happens.
  8. AwesomeSarah
    AwesomeSarah Member
    726
    The T.I.P collapsing is usually the older version of the 210bhp engines
    It may be worth having a look at the throttle body
    Give it a clean and realign
    Also check out the turbo hoses too
    As with that remap it relys on the turbo so make sure all pipes areb secure
    Sarah
