audi s3 8p window problem??????????
S3 syc May 8, 2013
  1. S3 syc
    S3 syc Active Member
    154
    29
    Just recently ive come out to my car and both windows have been all the way down,at 1st i thought i might have leant on the key but definatley not this time. has anybody else ever had this problem?
  2. coreythorny
    coreythorny Active Member
    463
    74
    Only issue I get with mine is the drivers side, if you use the button in car and pull up twice to auto raise fully, it does then stops and lowers a inch of two. Works ok manually.
  3. fireheed
    fireheed Member
    34
    You need to reset the auto function. Raise the window all the way up. Let go of the switch then pull it up again and hold for 2/3 seconds and that should be it.
  4. ozzy786
    ozzy786 New Member
    15
    Tried this several times with no luck ;((( didn't realise how often I use this feature until now!
  5. MEddy78
    MEddy78 New Member
    24
    Does the glass go up / down ok? No stiff or impeded travel?
  6. Krony
    Krony Active Member
    138
    52
    I get a similar problem very occasionally when i close both front windows at the same time in auto, sometimes the passenger window will come back down about 3-4 inches.
