AUDI S3 8P STEERING RACK PROBLEM - HELP!!!
Paul-S3 Jun 10, 2011
  1. Paul-S3
    Paul-S3 Member
    252
    Hi guys
    My steering rack on my 2007 s3 is fudged and i need a new one. I've been offered one second hand off a low mileage 2010 car. will this fit my 2007 s3 ok?
    Thanx
  2. Paul-S3
    Paul-S3 Member
    252
    ANYONE???????
  3. poli84
    poli84 Member
    425
    57
    [​IMG][​IMG]I installed a 2007 S3 steering rack into my old 2006 A3 with no problems at all.
    As I am a consultant to Audi Auastralia, I spent a lot of time discussing this issue with the National Service Manager and was advised that you can install a newer rack but not an older one.
    The below is information received from him which should answer your question pretty thoroughly.
    I was advised (I ended up finding a wrecked S3) that if I was to buy a new rack, it would be part# 1K2 423 055J to fit my old 2006.
  4. NCRAW
    NCRAW Member
    230
    Good info poli. Sadly most of Gen2 steering racks will be replaced at one stage or another i believe. I had a new one installed and it does feel different than the old one. more sensitive and more rd feel. my original one started squeeking at low speeds and turns. I would go back to Audi and insist they pay for at least the part or the labor. this was a faulty part with so many reported issues and breakdowns yet they never did a recall. If they want a list of how many people suffered from this then i reckon we can give them at least 50 names!!
  5. Ads
    Ads License to drive
    8,230
    607
    Audi will give you a couple of hundred discount on a new rack if you hand in your old rack.
  6. Paul-S3
    Paul-S3 Member
    252
    Thanx for the advice poli84. Looks like it should fit. I've already tried audi and they didnt wanna know. I've been offered a 2010 rack for £100 and it's covered just 8k, so i'm just gonna go with that i think. Thanx
  7. poli84
    poli84 Member
    425
    57
    Shouldn't be an issue.
    Good luck, let us know how you go.
  8. dc240969
    dc240969 Member VCDS Map User
    925
    How much are these new?
  9. NHN
    29,300
    1,703
    New are £930 odd, but be warned, the gen 2/3 required looms aswell, so check with parts department as it shows them a note when they click on the item, all racks are being replaced for gen 3 if they come in for them now.
    8P racks are synonymous for issues, especially the creaking noise & the clonk you get on full lock, cant remember if was left or right lock, think was right, hence why audi have untold stocks of these in stores, last time I checked there were 2-300 odd which with parts is fairly unheard of unless its a service item lol.
    I would bug audi for goodwill as they know of the issues for sure.
  10. dc240969
    925
    Since mine is now just out of warranty how do you think l would stand if l brought this to their attention and was found to be indeed the rack.
  11. NHN
    29,300
    1,703
    You stand a better chance than most I'd say, they have a 5yr cut off afaik & when pressed on something they're aware is a known issue, that they wont openly admit, they will offer something, but its a bit pick/mix with dealers, as some are just pita's, but some are very understanding & will ask audi uk what they can do.
  12. Khufu
    Khufu Well-Known Member
    5,704
    31
    were gen1 ok? I'd hate to think mine is going to go somewhere down the line...
  13. dc240969
    925
    Mines a Gen 1. l noticed this creaking or it sounded like fluid gurgling some time ago, well over a year. l was told it was the haldex. Or a top mount needing greased. lve no idea how to get access to a top mount.
  14. NHN
    29,300
    1,703
    Remove shock & its at the top lol
  15. Fandango80
    Fandango80 Member
    71
    I just had my 07 s3 rack replaced by audi under warrenty. My mate works there and he said that its a 2010 rack but they have to plug the car into their diagnostics to program it. The ECU apparently talks to HQ in germany and registers the rack with the car. Without this, it apparetly wont work. There are also settings which makes the rack perform differently. He set mine up on an Rs3 program and amazingly it made absolutely no difference to the feel of the steering :sly:
    Thought id let you know about the programming incase it is a problem.
    Cheers.
  16. NCRAW
    NCRAW Member
    230
    Dont believe that ****, thats what they told me too and supposidly followed AUDI instructions and "fixed" the issue by lubing the strut tops only for it to happen again 24 hrs later.
  17. poli84
    poli84 Member
    425
    57
    This is what has happened to me too.
    I've already at it at Audi with the creaking problem and they dismantled the suspension and lubed the strut tops.
    I'm waiting for it to come back again. Although I'm a little worried that if it happens after I've installed the ARB's, they will blame them for the creaking noise.
  18. NHN
    29,300
    1,703
    Just re-read this, the top mount isnt 100% sealed but certainly isnt something that you can whack loads of grease into, if its got road grit in, dust etc which happens often it could over a period of time cause wear on the internals & make them loose, only when I did my suepnsion upgrde did I realise mine wernt in good condition, hence swapped out.
    +1
    Creaking issue is nothing to do with the struts, typical audi fob-of, its from the rack itself.
  19. kaitracid
    kaitracid New Member
    12
    Hi, I have problems with servo steering. Most of the times, servo doesn't work and the servo witness on the dashboard is mostly on than off. Is it the power steering box or another thing (like ECU)? I am searching for a SH power steering box, but can't find one with exactly the code that I have on mine. Oddly, I can't find this code in Etka. I will attach a photo so you can see, there are two codes, 1k1 909 143 J and 1k1 909 142L. The A3 is from 09/2003, so it's first generation A3 8P.
    Can you tell me which steering box would work? I am also asked if I have 2 or 3 wires to connect it, but I have no idea, now I drive the car in this condition.
    [​IMG][​IMG]
  20. NHN
    29,300
    1,703
    I have a rack for sale, of an early BKD aswell.
    The part number is actually stamped into the metal somewhere, that is not the rack part number you've shown.
  21. mrpeng
    mrpeng 2.0T Quattro
    78
    dam heard that creaking on mine when you turn the wheels while stationary. looks like i be going to audi to get ripped of aswell my car is 2005 way out of warranty only 30k on clock but i guess they will still say wear and tear
  22. davc
    davc Well-Known Member Team Glacier Audi S3 quattro s tronic saloon
    601
    576
    93
    Mine started making the same gurgling noise last week, and I've got a squeak when turning at low speed. Me thinks the recon'd rack I got this time last year is goosed:applaus:
  23. John ler
    John ler Member
    150
    Sorry for bringing an old thread back to life, but can anyone help me, I'm trying to find a part number for a steering rack on a 2010 s3 cdla , can anyone help me cheers
  24. davc
    601
    576
    93
    1K2 423 055 K or
    1K2 423 055 KX
  25. Thai Boxer
    Thai Boxer New Member
    19
    Does anyone know the part numbers for a 2004 2.0 tdi sport steering rack and control module?
    Really need them asap. Thanks guys.
  26. John ler
    John ler Member
    150
    I have one bought in error from a 2013 8p complete
  27. S3 AEX
    S3 AEX Active Member
    747
    211
    43
    How much?
  28. John ler
    John ler Member
    150
    Looking for £200, I paid £250 + postage of £35, the can had only done around 8-9,000 miles , was like new, cheers
  29. Stevochet
    Stevochet New Member
    hiya, did you ever sell that steering rack? think ive just got the same problem, i jumped into my 2.0 fsi turned it on and a red steering wheel popped up and the steering has gone super heavy
