Audi S3 2008 Needle Sweep VCDS
pinterovski Nov 11, 2012
  1. pinterovski
    pinterovski Member
    667
    88
    Hi!
    I am trying to do this thru the VCDS and it seems that i dont have the long coding
    helper to activate this! I believe this is the thing but like i said,i dont have the this options!
    [Select]
    [17 - Instruments]
    [Coding - 07]
    [Long Coding Helper]
    Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
    Check the box for "Gauge Test/Needle Sweep active"
    [Do It!]
    Is there any other way to activate this?
    My car is year 2008,so i think it should have the right cluster for needle sweep!?
    I checked the whole forum and i didnt find any right anwers! If i missed some good thread
    how to activate this than post the link please.
    Cheers!
    J.
  2. pinterovski
    pinterovski Member
    667
    88
    Anybody?
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Give people a chance to reply man!
    Especially 'cos its Sunday - we don't live on the forum 24/7 yano!
    What colour is your DIS? Iirc it's only available on white clusters.
  4. pinterovski
    pinterovski Member
    667
    88
    DIS colour is red. A friend of mine also has this feature on his prefacelift S3 year 2007,mine's 2008.
  5. a6_chris
    1,883
    160
    Try going into Adaption instead of coding and see what the drop down menu says.
  6. Reload
    Reload Bird is the Word!
    367
    49
    Had a look into this for my 2007 S3 with no joy, don't think it can be done but will be interested to see if this isn't the case
  7. AndyParker
    AndyParker Active Member
    320
    Have you guys got a video of what you are trying to achieve?
    I ask because I think mine does the needle swap back and fore on ignition on - mines a 57 plate 2007 8P2 with red DIS
  8. Gizmo68
    Gizmo68 VCDS & VCP owner in Kent VCDS Map User
    88
    on every car I have enabled this it was done under the ‘Adaptation’
    You are looking for “Staging”
