Audi S3 2008 Facelift Adaptive Xenons Coding Issues
Usual Suspect Jan 22, 2013
  1. Usual Suspect
    Usual Suspect New Member
    Hi everyone!
    Trying to help a mate out who has recently face lifted his S3.
    His car was originally a 2008 S3 pre facelift which had factory fitted adaptive Xenon headlights.
    He has now installed the later front end alongside the later headlights.
    These headlights are also adaptive.
    I have manage to code in the headlights to work and light as they should but cannot seem to code in the adaptive modules.
    I am currently getting the following fault codes:
    Tuesday,22,January,2013,16:08:33:60804
    VCDS Version: Release 10.6.0
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Control Module Part Number: 4F0 910 357 F HW: 4F0 907 357 F
    Component and/or Version: AFS 1 H01 0020
    Software Coding: 0000255
    Work Shop Code: WSC 06314 000 00000
    Additional Info: 7L6941329B AFS-Modul links H02 0005 7L6941329B AFS-Modul rechtsH03 0004
    VCID: 29527852F991
    4 Faults Found:
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:54:38
    01042 - Control Module; Not Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:54:38
    02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:54:56
    02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 81
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:54:56
    The only issue remains is the fault on the dash for the adaptive lights alongside the errors in Control Module 55. The central electronics have coded up fine.
    I have tried to code the module, however does not accept the coding which makes me believe that the headlight control module does not support the new headlights. I think this maybe due to the XENON module (55) not accepting the code due to the module not being compatible with the later adaptive lights.
    I have logged in using VCDS with the Security Access Codes 02000 before trying to Change the coding but it has failed to do so... Bringing up:
    "Coding rejected"
    "Error 78: unknown"
    The current coding is 0000255 code and i have tried to change it to A3 8p 0000020 following Ross techs instructions:
    http://wiki.ross-tech.com/wiki/index.php/Audi_A8_(4E)_Headlight_Aim_Control_(Adaptive_Light)
    I have tried to change it to all other possible values but it does not have any...
    I cannot perform basic settings either after logging in with the security codes no matter what I try.
    I believe the vehicle may have an earlier AS1 module and I require and AS2???
    I have a later module part number 8P0 907 357J, however this has a different plug so i cannot directly replace or test this unit.
    As the vehicle originally had factory Xenons it is equipped with all the levelling sensors washers etc... So all the wiring I'm guessing should be there.
    I've been reading through other posts and cannot really see anyone who has done a similar upgrade, unless I missed it.
    Can anyone shed some light on this.
    Many thanks
  2. Usual Suspect
    Autoscan of car before any adjustments were made
    Data version: 20100630
    Tuesday,22,January,2013,15:05:50:60804
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76
    VIN: WAUZZZ8PX8A003316 Mileage: 71570km/44471miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 1010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    76-Park Assist -- Status: Malfunction 0010
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0050
    Revision: 5BH16--- Serial number: AUX7Z0G4FNM0QK
    Coding: 01030003180F0060
    Shop #: WSC 00191 264 15243
    VCID: 3776AE2A3F25
    2 Faults Found:
    005634 - Power Supply Terminal 30: Voltage too Low
    P1602 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: -40.0°C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    000406 - Engine Oil Temp. Sensor (G8): Implausible Signal
    P0196 - 004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:47:09
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 5.0°C
    Temperature: 7.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 10.287 V
    Readiness: 0110 0100
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0004744
    Shop #: WSC 06314 000 00000
    VCID: 72E05F3E14C7
    3 Faults Found:
    00668 - Supply Voltage Terminal 30
    01324 - Control Module for All Wheel Drive (J492)
    013 - Check DTC Memory - Intermittent
    001 - Upper Limit Exceeded - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
    Component: KlimavollautomatH19 0420
    Revision: 080873 Serial number: 8P0820043AH
    VCID: 72E05F3E14C7
    5 Faults Found:
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 116
    Mileage: 71573 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:18:50
    Freeze Frame:
    Voltage: 7.40 V
    01331 - Door Control Module; Driver Side (J386)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:13:00
    Freeze Frame:
    ON
    01332 - Door Control Module; Passenger Side (J387)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:34:05
    Freeze Frame:
    ON
    01273 - Fresh Air Blower (V2)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 71573 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:18:53
    Freeze Frame:
    Temperature: -50.0°C
    Speed: 325.0 km/h
    (no units): 154.0
    (no units): 248.0
    01206 - Signal for Duration of Ignition Off Time
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:00:07
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007138936
    Coding: F58E1F07A0141000470000000000000000084E175A050000000000000000
    Shop #: WSC 06435 000 08192
    VCID: 458AD4E275C9
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06435
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150573
    Shop #: WSC 06435
    10 Faults Found:
    03098 - Left Rear Turn Signal Lamp (M6)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:00:00
    Freeze Frame:
    OFF
    Voltage: 13.25 V
    OFF
    OFF
    OFF
    OFF
    OFF
    03099 - Right Rear Turn Signal Lamps (M8)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:00:00
    Freeze Frame:
    OFF
    Voltage: 13.25 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00987 - Lamp for Brake Light; Left (M9)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:34:00
    Freeze Frame:
    ON
    Voltage: 13.75 V
    ON
    ON
    OFF
    OFF
    OFF
    00988 - Lamp for Brake Light; Right (M10)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:34:00
    Freeze Frame:
    ON
    Voltage: 13.75 V
    ON
    ON
    OFF
    OFF
    OFF
    02394 - Parking Light Left Front (M1)
    Freeze Frame:
    Fault Status: 01111100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 71574 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 11.75 V
    OFF
    ON
    OFF
    OFF
    OFF
    02395 - Parking Light Right Front (M3)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 01:11:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    00984 - Left Tail Light (M4)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 01:11:00
    Freeze Frame:
    ON
    Voltage: 14.30 V
    ON
    ON
    OFF
    OFF
    OFF
    01518 - Bulb for Back-Up Lights; Left (M16)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:34:00
    Freeze Frame:
    ON
    Voltage: 13.65 V
    ON
    ON
    OFF
    OFF
    OFF
    00978 - Lamp for Low Beam; Left (M29)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00111010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 119
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:34:00
    Freeze Frame:
    ON
    Voltage: 13.85 V
    ON
    ON
    OFF
    OFF
    OFF
    00979 - Lamp for Low Beam; Right (M31)
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 119
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:34:00
    Freeze Frame:
    ON
    Voltage: 13.85 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
    Component: Airbag 9.41 H01 4230
    Revision: 91H01423 Serial number: 003CR0G00BK3
    Coding: 0070612
    VCID: 4D9AECC2ADB9
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 120
    Mileage: 71573 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:19:04
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0002012
    VCID: 4182C0F261E1
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
    Component: KOMBIINSTR. VDO H20 0630
    Revision: D0H20001 Serial number: 2244G001000684
    Coding: 0037428
    Shop #: WSC 01048 000 00000
    VCID: 4182C0F261E1
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 119
    Mileage: 71562 km
    Time Indication: 0
    Date: 2012.03.13
    Time: 23:22:12
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K075188880
    Coding: E9831F0E4002020101
    VCID: 30649536DA4B
    4 Faults Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 92
    Mileage: 70872 km
    Time Indication: 0
    Date: 2012.01.21
    Time: 12:11:24
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 71573 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:19:49
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:00:03
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 00:00:01
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 3668A32E382F
    1 Fault Found:
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H20001 Serial number: AUX7Z0G4FNM0QK
    VCID: 4182C0F261E1
    No fault code found.
    Address 37: Navigation Labels: None
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H05 0200
    Revision: 0000011S Serial number: AUZBZ7KD202955
    Coding: 0225725
    Shop #: WSC 00588 210 88196
    VCID: 346C99262E53
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 120
    Mileage: 71562 km
    Time Indication: 0
    Date: 2012.03.14
    Time: 21:36:37
    Freeze Frame:
    Voltage: 12.70 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 16
    Reset counter: 120
    Mileage: 71561 km
    Time Indication: 0
    Date: 2012.02.24
    Time: 11:46:54
    Freeze Frame:
    Voltage: 12.70 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    00856 - Radio Antenna
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 119
    Mileage: 71562 km
    Time Indication: 0
    Date: 2012.02.28
    Time: 00:01:07
    Freeze Frame:
    Mileage: 71570 km
    Count: 1903
    Clock: 10:54
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 69175 km
    Time Indication: 0
    Date: 2011.12.28
    Time: 14:59:14
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 69175 km
    Time Indication: 0
    Date: 2011.12.28
    Time: 14:59:00
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 69175 km
    Time Indication: 0
    Date: 2011.12.28
    Time: 14:59:03
    Freeze Frame:
    Bin. Bits: 00000100 00000000
    Bin. Bits: 00000000 00000000
    Bin. Bits: 10000000 00000000
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
    Component: Tuer-SG H04 0101
    Coding: 0004660
    VCID: 4894DDD642DB
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.150 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 3668A32E382F
    2 Faults Found:
    Freeze Frame:
    Mileage: 71560 km
    Temperature: 15.0°C
    Voltage: 6.40 V
    Voltage: 6.20 V
    00778 - Steering Angle Sensor (G85)
    000 - -
    Freeze Frame:
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 F
    Component: KSG H05 0070
    Coding: 9980202002186D298F0F489AC637
    Shop #: WSC 00846 012 00012
    VCID: 3F86C60A1715
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    5 Faults Found:
    01134 - Alarm Horn (H12)
    00955 - Key 1
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
    Coding: 0004660
    VCID: 4992D8D259D1
    1 Fault Found:
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000255
    VCID: 29527852F991
    Part No: 7L6 941 329 B
    Component: AFS-Modul links H02 0005
    Component: AFS-Modul rechtsH03 0004
    7 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:19:48
    02071 - Local Databus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 8
    Reset counter: 40
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:19:57
    02234 - Right Headlight Power Output Stage (J668)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:21:12
    02233 - Left Headlight Power Output Stage (J667)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:21:12
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 01:10:53
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 01:10:56
    002 - Lower Limit Exceeded - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 80
    Mileage: 71576 km
    Time Indication: 0
    Date: 2012.03.23
    Time: 01:13:15
    Address 56: Radio Labels: None
    Coding: 0225725
    VCID: 346C99262E53
    6 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 120
    Mileage: 71562 km
    Time Indication: 0
    Date: 2012.03.14
    Time: 21:36:37
    Freeze Frame:
    Voltage: 12.70 V
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 7
    Fault Frequency: 17
    Reset counter: 80
    Mileage: 71561 km
    Time Indication: 0
    Date: 2012.02.24
    Time: 11:46:54
    Freeze Frame:
    Voltage: 10.40 V
    Mileage: 71570 km
    Count: 2303
    Clock: 00:02
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 119
    Mileage: 71562 km
    Time Indication: 0
    Date: 2012.02.28
    Time: 00:01:07
    Freeze Frame:
    Mileage: 71570 km
    Count: 1903
    Clock: 10:54
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 69175 km
    Time Indication: 0
    Date: 2011.12.28
    Time: 14:59:14
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 69175 km
    Time Indication: 0
    Date: 2011.12.28
    Time: 14:59:00
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 8
    Mileage: 69175 km
    Time Indication: 0
    Date: 2011.12.28
    Time: 14:59:03
    Freeze Frame:
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
    Component: Parkhilfe 4-Kan H09 0070
    Revision: 00H09000 Serial number: 00067824830713
    Coding: 0000113
    Shop #: WSC 131071 1023 2097151
    VCID: 3C7CB1060603
    6 Faults Found:
    01548 - Sensor for Parking Aid; Rear Right (G206)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:16:41
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:16:41
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:16:41
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 116
    Mileage: 71573 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:19:49
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 116
    Mileage: 71573 km
    Time Indication: 0
    Date: 2012.03.17
    Time: 01:18:59
    02070 - Rear Parking Aid Sensors
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 120
    Mileage: 71574 km
    Time Indication: 0
    Date: 2012.03.19
    Time: 00:16:09
    End ---------------------------------------------------------------------
  3. NHN
    29,300
    1,702
    This forum does not support the use of illegal counterfeit cables.
