Audi S3 2008 Built (8P). Retrofitted Cruise Control. NEW ECU or no ECU?
moley147 Nov 14, 2011
  1. NHN
    29,594
    1,782
    Send me a PM mate & we can discuss the possibility :)
  2. mike foster
    3,967
    It is possible to install CC without having a DIS (Driver Information System) but it is likely that you will need a new steering control module as well as the new stalk. Cost of parts is likely to be £250 ish plus fitting and coding.
    Depending on whereabouts you are in the country (assuming you are in UK ) then there are members of this forum who could do it for you.
    Have a search on the forum and see what you can find.
    Welcome to ASN by the way !
  3. mike foster
    3,967
    ****** - you beat me to it !!
    Have you checked your inbox on the other forum ?
  4. danmckinstry
    danmckinstry New Member
    15
    Its not the cruise control im wanting to get fitted, its the DIS. Is this possible?
  5. mike foster
    3,967
    Sorry mate - my bad !
    Nige - he hasn't enough posts to PM so it's up to you
  6. danmckinstry
    15
    No bother mate. Ive been in touch with loads of garages around my way and its the same answer from all of them, impossible! But on many forums people say they have done it.
  7. mike foster
    3,967
    I bet NHN can do it - do you want me to PM him for you ?
  8. danmckinstry
    15
    If you wouldnt mind mate. How come i cant private message?
  9. mike foster
    3,967
    You need a minimum number of posts (not sure how many) before you can PM. You haven't enough yet !!
    I'll PM him.
  10. danmckinstry
    15
    Oh ok mate, thanks a lot.
  11. danmckinstry
    15
    Has there been any news on the subject lads?
  12. NHN
    29,594
    1,782
    Yes a dis can be fitted, but you need a dis cluster which requires immo coding, plus a new wiper stalk & maybe a sensor for the water level.
    Whereabouts are you located?
  13. danmckinstry
    15
    It already has a water level indicator (if your talking about the window washer fluid). I'm in middlesbrough mate. How much is all that going to cost about?
  14. danmckinstry
    15
    Would you be able to do it for me, if I came to you mate?
  15. NHN
    29,594
    1,782
    I'm in the south east, but yes it could be done.
  16. danmckinstry
    15
    Do you know of anyone in the North East who is capable of doing it?
  17. NHN
    29,594
    1,782
    Its finding someone who can code the cluster in, I may know 1 person but I have to ask him 1st.
  18. danmckinstry
    15
    If you would do mate would be much appreciated. Private message when if you get in touch with him because I think I've made enough posts now. Cheers
  19. danmckinstry
    15
    If I came to you mate how much would I be looking at paying?
  20. moley147
    moley147 Member
    40
    Many thanks to jb0o for installing my Cruise Control.
    I had been waiting for months for my mate to get around to it (you know what its like) but I contacted Jonny on Friday and he installed it on Sunday.
    No problems whatsoever. Test drive. Service with a smile. Hassle free. Just what you'd expect from an expert retrofitter.
    Cheers :)
  21. RapidAssistant
    RapidAssistant Member
    104
    Same issue with me - I had CC in my old A4, but the A3 I have replaced it with doesn't. Mines is 2009MY with the white DIS and the MFSW, so I assume all I need is the combined CC and indicator switch, a new lower moulding for the steering column, and someone who knows his way around VAG-COM to program it to the car??? Anyone have any ideas how much the switch costs?
  22. mike foster
    3,967
    CC retro-fit kit part no. :- 8P0 054 690 £62.29
    Lower cowl part no. :- 8P0 953 512 A £28.68
    These are ETKA prices from a dealer. Ring Dave at Stoke Audi for discounted prices but you will have to pay postage.
    Apart from VCDS coding you will also need a 12mm spline bit to remove the steering wheel
  23. Nigel Edwards
    Nigel Edwards New Member
    Can anybody let me know a fitter in the Weston-super-Mare / Bristol area. I have fitted a multifunction steering wheel and have the stalk and lower cowl to fit cruise control to an 07 Audi S3.
    I need somebody to programme the car for me so the bits work. Any ideas???
  24. mike foster
    3,967
  25. Dracue
    Dracue New Member
    Hi Guys
    Been reading through the posts and I've just purchased an A3 TDIE and am looking for parts and install for Cruise Control if anyone's in or near Bristol?
    Cheers.
  26. crunchie
    crunchie Active Member
    880
    77
    I have a 58 plate S3(facelift) and have fitted Cruise Control myself.
    Bought it from Huntingdon Audi off eBay. Supplied my reg so I knew I got the correct one.
    Car was in at Highland Audi for a n/s/f wheel bearing(yes at 21k!!) and asked the tech to code it in.
    He came back to me when I picked the car up to say that he was unable to code it as the coding was not accepted.
    He also said that my RNS-E was not coded(which its not) and that may have something to do with it?
    I'm unsure why this would be?
    The RNS-E works perfectly well without being coded so wasn't that fussed.
    Has any one had any similar issues?
    Any info would be appreciated, cheers.
  27. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Lol, what a load of BS! Find someone close to you with VCDS and get them to code it in for you.
  28. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    As Jonny said, 9 out of 10 times, the dealers are clueless on retrofits and coding!
  29. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,002
    11,147
    Crunchie, few of the guys will be in aberdeen today, if you could get there, sure Mark will have his vcds on him. If not, try sending Mark (brodster) a pm, he will be up in elgin area in the next few days to take his kids home, so he may be able to help you out. :)
  30. crunchie
    880
    77
    Thanks for this Sandra. Unfortunately I'm off shore until Thursday. I may PM him to try and arrange something for when I get back.
    Thanks again.
  31. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    is there anyone in the South that does the CC retro fit? Near to portsmouth as possible, i dont have a MFSW but have the computer, sombody got a rough price in mind?
  32. Sandra
    28,002
    11,147
    Try user dannykn9. :) x
  33. Sandra
    28,002
    11,147
    ok Crunchie, if you can get to Banchory on the 28 th let me know and i will organise a vcds scan time for you. :) x
  34. Dannykn9
    1,123
    56
    Cheers Sandra.
    Chris, have sent you a PM mate.
  35. Ginger Prince
    Ginger Prince Member
    189
    Hi all,
    I live in Manchester and have an Audi S3 (8P) with the trip computer.
    Im looking to also have cruise control fitted (probably October).
    Is there anyone near me or in the North West that can be be recommended and how much am I looking at please?
    Mike
  36. Dannykn9
    1,123
    56
    Hi mate,
    I sometimes drive to Manchester, but otherwise you could get a user here called N8 to arrange it for you as he is set up around Manchester. Sure he will look after you and sort out a good price.
  37. GStatus
    GStatus Member
    122
    21
    I'm looking for someone to retrofit the cruise control for me please,
    53 plate 8P with Trip computer
    Im in the East Midlands
  38. NHN
    29,594
    1,782
    Ping me a PM mate as I have work in that area soon :)
  39. Ginger Prince
    189
    Cheers Danny, Nigel said the same so i'll see if I can find him on here.
    Mike
  40. Dannykn9
    1,123
    56
    Here is a link to Nathan's (N8) profile where you can PM him fella.
    View Profile: N8 - Audi-Sport.net
