Audi S3 02 plate tuning advice!
shrink_777 Mar 22, 2009
  1. shrink_777
    shrink_777 New Member
    :greyrs4:
    New to all this so 4give if i have made any errors! recently got S3, its got a Superchip, milltek and the Brembos jnrs (which it didnt now I have seen the price of discs and pads) what other mods can i put on? I aint got grands to spend on it but i dont mind spending a bit?? any ideas anyone? cheers people :arco:
  2. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
    suspension is the one you want to upgrade.
  3. shrink_777
    Yeah i got some lowering springs aswell but if i get a diverter valve? fmic? are these worth it??
  4. Dani_B19
    9,048
    337
    Just search the 8l section pal, theres loads of threads thatll point you in the right direction
  5. voorhees
    16,126
    1,968
    Forge 007p Diverter Valve.fmic will prevent heatsoak.
    upgrade your N75 valve to an N75 'J' I did mine and noticed more mid range power also your hoses as standard ones can collapse with a remap.
  6. andrewcyp
    andrewcyp New Member
    10
    N75J does a good work..try changing the spark plugs as well use the
    Bosch F5DPOR or the NGK BKR7E but change the gap to 0.28inches(only for the NKGs).
    as well as that go for an air filter as well as a turbo inlet...:blackrs4:
  7. dunk
    dunk Member
    770
    minor stuff like valves and air filters isnt going to do anything noticable to your car apart from reduce your bank balance
    sort out the suspension to use the available power - an upgraded anti-roll bar (particularly the biggest rear you can find) will reduce understeer and a bit of lowering and better dampers will add some front negative camber (you need to max out both bottom ball joints as well) and improve things no end, all within your budget.
  8. thorsy22
    thorsy22 Member
    308
    Read the stickies at the top of the A3/S3 8L section.
