Audi Radio Symphony 2 HELP PLEASE
jacks3 Oct 7, 2012
  1. jacks3
    jacks3 New Member
    My car is a 2001 Audi S3 8L running a bam engine.
    I have the genuine Audi symphony 2 radio, i seem to have a problem where only the screen lights up non of the buttons, also the radio dose not turn on or off with the ignition switch like it should, this weekend I had chance to try another radio that works fine in another S3 8L plugged it and it was still the same i tryed my radio in the other car and everything worked fine and all the light worked fine and turned on and off with the key
    So my radio seems to work fine so i dont really know what to do or try next i have checked the radio fuse and the fuse on the back of the radio and they are fine and was not sure if anyone else has ever come across this problem or if anyone had any advice on things to try.
    Also I am pretty sure on speedo screen it should show what radio station is on or what cd etc is this right?
    please help me it drives me insane.
    Thanks Jack S3
  2. Stutibs
    Stutibs Member
    51
    im having this problem, did this ever get solved?
  3. jacks3
    jacks3 New Member
    Hello no i have had no reply or help on this one someone at a local audio specialist said it might be wire that controls the lights.
    i am very confused as i am not good with wiring.
    Jacks3
  4. AndyMac
    9,832
    45
    Sounds like the CANBUS interface is not working properly. The CANBUS is a data bus that controls the ignition on/off and the DIS info, so if both aren't working then it is either not plugged in or not working. The CANBUS is the middle section of the top connector on the back of the HU.
    Might be worth getting the car scanned with VCDS to see if there are any CANBUS errors.
  5. Stutibs
    Stutibs Member
    51
    I have tried connecting vagcom and have a comm fault with radio and instrument cluster. So im none the wiser as to where the issue lies. Sorry to bring an old thread to life but this is driving me slowly mad
  6. jacks3
    jacks3 New Member
    Your telling me I haven't managed to find anyone that is around my arena to scan my car all I know if that its about drove me insane.
    Please help us Audi fans
    thaks
  7. Stutibs
    Stutibs Member
    51
    Quick update for you lovely people. I have fixed my radio/dis problem stripped the radio down not faults found in there traced the wiring back and found a small break in the wire. Repaired and heatshrinked it. Now works a treat!! Illumination, dis and turns on and off with ignition. Couldn't be happier.
  8. jacks3
    jacks3 New Member
    Grate news mate how far back was the split and how easy was it find it? I might try and strip mine down Saturday.
    Im about at my whits end with mine now.
    Hope I can sort mine.
    Jack S3
  9. Stutibs
    Stutibs Member
    51
    It was about 15cm from the connector. Good luck mate hope you can get it sorted
  10. jacks3
    jacks3 New Member
    Just before I start looking though everything what colour wire was broken as we must have the same colour broken to have the same fault I cannot wait to try and sort this is has been bugging me.
    JackS3
  11. Stutibs
    Stutibs Member
    51
    Cant help with colour im afraid as I am colour blind. It was the can -h wire traced out the back of the stereo
  12. Levoi
    Levoi New Member
    Hi I know this is an old thread but I have just had the same problem Jacks3 what colour was the faulty cable in the end as I'm guessing you have fixed it by now HAHA
  13. goodbuzzman1
    goodbuzzman1 Active Member
    505
    57
    i had a similar problem after i removed my dash clocks, and i didnt re-connect one of the plugs right and had no lights on my stereo
  14. Stuart B
    Stuart B Well-Known Member
    1,569
    285
    An old thread I know but since I got my radio working with the Symphony 2 replacing my Symphony with Faulty CD. I wouldn't mind getting the DIS and Ignition to work. I have put all the plugs in and can talk to the radio using VCDS - as I tried to set it into BOSE mode recently. what I will point out is occasionally my front speakers don't seem to work, they do at the moment but they didn't yesterday.
    I am pretty sure it will work as I saw tufty manage to program the DIS to show Sat Nav instructions on his RNS-E thread.
    Thanks for any hints :)
