Audi Q7 battery dies what do these fault codes mean?
vw754 Feb 21, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,334
    58
    If i start and drive the car lets say at 12pm and i leave it sitting for a good12-14 hrs the car will just about turn over and start, on tuesday i parked the car up and today(thursday morning) battery was flat...i had to get out the jump leads to start it.
    Audi fitted a brandnew battery end of dec 2011
    I hooked up vcds and deleated previous faults,then did a full scan..........this is what i got
    part no: 4F0 910 177
    : 1 fault found 01699-motor for central locking hatch/trunk (v53)
    009- open or short to ground
    freeze frame fault status 01101001
    fault priority 3
    fault frquency 254
    reset counter 137
    time indication 0
    date 2010 12 15
    time 16:18:53
    1 fault found:
    02244-BUTTON ON CONTROL HEAD STUCK (this cleared when i messed with the sat-nav button)
    03073 rear lid closed sensor 1
    008 implausible signal-intermittent
    priority 5.
    2 faults found
    02256 quiescent current
    001-upper limit exceeded-intermittent
    priority 7.
    03041 energy management active
    000----intermittent
    priority 7
  2. gupsterg
    gupsterg Active Member
    348
  3. vw754
    2,334
    58
    nice one,my cars a 56 plate....will audi have to do that?
    one more thing,ive been messing with all the buttons in the car and mileage has changed from miles to km,how do i change it back?
  4. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    You can change it back to miles with VCDS
  5. vw754
    2,334
    58
    done it via the car,thanks for the reply
  6. gupsterg
    348
    No I did mine at home... I used a battery charger on the slave points under bonnet...
    If you have bluetooth run disc 2 twice, so you would be doing disc 1 once, disc 2 twice, disc 3 once...
    If you do not have bluetooth you would be doing disc 1 once, disc 3 once...
    People have done it with the engine running but I'm not a fan of that as when flashing you really don't want voltage variance,etc...
    Empty CD changer use slot one... the MMI FW update will only update what needs to be updated... ref the screenshots in the PDF above...
    2G MMI HIGH v5570 update disk part no 4L0 998 961 is available on ebay but IIRC Audi dealer is cheaper (less than a £10)...
    They can get iffy about supply but will sell them to you... MMI update can take upto an hour...
    Early hardware versions of bluetooth modules can sometimes not like a flash update but other modules in your car may not as well...
    Flashing is not risk free...
    make your own mind up and do what you wish...
    Use google and search for mmi flashing failure or mmi update issue ... etc etc etc ...
    Plenty info on web... try to use as least amount of electrical items in car when flashing, use a charger...
    Switched off AC/blower... switch off interior lights, any "Auto" functions like coming/leaving home lights, etc,etc...
    On my A6 I did lose "Battery Meter" & "Instrument Cluster" menus in "Car" menu but by VCDS you can re-enable those...
    The MMI update does all MMI related modules (Radio unit, AMP, etc) ...
  7. vw754
    2,334
    58
    i dare not try that.......too technical for me,and if it goes wrong im done!
  8. vw754
    2,334
    58
    Just a thort,is it good to get my battery tested by car spares/auto shop.......audi fitted a new one in may 2011 and if im right all audi parts carry a 2 year warranty?..........maybe its just a battery issue?
  9. gupsterg
    348
    You can do measuring blocks in the battery regulation module...
    Link:- Audi Portal: ECU Diagnostic . Audi Q7 4L (2007- ) . Energy Manager J644
    SOC (State of charge) is a good one top look at...
    With the MVB's in above you can also see if the alternator is functioning correctly on charging,etc...
    Yes genuine Audi parts have 2 yrs warranty... with VAS they can see even more battery data/history than what VCDS can...
    For MMI update they may charge an hours labour... highlight the TPI/TSB then they will do it without diags charge possibly...
    I've seen posts where they replace the battery first then when customer still has issue then they do MMI update...
    One guy had an alternator changed, then battery then finally they did MMI update as neither the first two bits of work fix issue...
    They did the update for free after they had charged for the alternator & battery...
  10. vw754
    2,334
    58
  11. gupsterg
    348
    In one of your photos SOC=80% so I would say battery is fine...
    You can press "PRT SC" on keyboard and then open paint and paste a screenshot and then edit/upload...
    I've recently been using this Link:- FastStone Screen Capture - The Best Screen Capture Software
    This allows you to capture screen, files are great sizes for uploading to youtube and you get no screen glare,etc,etc :) ...
  12. vw754
    2,334
    58
    after parked up for 16 hours,this morning started fine.
  13. vw754
    2,334
    58
    I had a new battery,coded it and its been ok,checked with vcds today,cars been standing for around 74 hours and atate of charge is 60% battery condition is 90% is that normal?
    battery management was activated ...i deleted all codes,now all codes have dissapeared
  14. gen.heinz guderian
    1,346
    126
    Hopefully thats sorted it out for you.
  15. vw754
    2,334
    58
    I had a new battery,coded it and its been ok,checked with vcds today,cars been standing for around 74 hours and state of charge is 60% battery condition is 90% is that normal?
  16. gupsterg
    348
    SOC so should not be 60% IMO ... battery condition in the MMI is =
    Its not a volts/amps meter...
    SOC =
    I had a new battery in Jan 13 ... I do very little miles a day... have plenty of toys in my car... my SOC is 80%+ depending on being stood for several days or none...
    Place a multimeter on battery lock car and see if you have a parasitic draw...
  17. vw754
    2,334
    58
    I drove the car to work today,a stright road to work with a few stop/traffic,and 11 miles each way,i checked state of charge and it was 80% and battery condition was 100%........then i did a full scan and here are the results (tried to clear them they pop right back up)
  18. vw754
    2,334
    58
    i wonder sometimes....if what i read has some truth?.............MMI upgrade? if that could help?
  19. gupsterg
    348
    Your MMI version is 4220
    I did a quick google of fault code from below section...
    Most info seems to suggest a drain occurring...
    You also have a AUX Heater... IIRC I've read some info within some A8 posts relating to draining with this, will dig it up...
    Get a multimeter on battery and monitor if drain happening after locking car up... parasitic draw ...
  20. vw754
    2,334
    58
    thanks mate,i dont know how use multimeter,but if it is pointing to drainage,id really appreciate it if you would dig up the cause,thanks.
  21. vw754
    2,334
    58
    how do these aux heaters work? also in 61-battery regulation, in measure blocks group 007 ive got this if it means anything
    ch1..... 0-19.......ch2.(count) 1 ...... ch3........Not ok...........ch4.......ok
  22. gupsterg
    348
    Hi,
    Did you fix issue?
    I can't seen any info for MVB 007 in module 61 on Audi portal... any chance of a screen shot?
    ATB
    G
  23. christof71
    christof71 Member
    60
  24. vw754
    2,334
    58
    Ive updated the mmi using 3 genuine audi cd's ,replaced battery and coded it,first few days (7 days) battery is still fully charged now after a couple of months sometimes it will still be fully charged after 4 or 5 days,i could go and check now and it could be fully charged(thats after the cars been sitting for 4 days) i could go to it tomorrow and it will show only 10% charge. i get a fault 01699 tailgate lock/hatch could this drain it?
    it works ok just get the flickering when the tailgate opens.
    Have i missed something? do i need to get rid of battery history or something?
  25. christof71
    christof71 Member
    60
    Make sure that your car does not require a service action to change the software to tailgate.
    "do i need to get rid of battery history or something?" YES
    I did use current clamps 50 amper {importent} and VAS 5052b .Maximum
    quiescent current consumption is 50 MiliAmper !!
    You have to close the car and wait about 10 minutes.
    Easier way is to read the history of the battery{vas5052b }
    or use VCDS and see in these values
  26. christof71
    christof71 Member
    60
    yes
    Maximum static current is 50 miliamper!
    i get a fault 01699 tailgate lock/hatch could this drain it?"
    yes
    First step -check your car for
    recall -tailgate software update.
  27. vw754
    2,334
    58
    il do that and get back to you thanks
  28. vw754
    2,334
    58
    is there a number i can call you on,if you have 5 minutes at some point to talk me through it????????
    if not il try do the 'audi portal' thing
  29. vw754
    2,334
    58
    DONT UNDERSTAND THIS: I did use current clamps 50 amper {importent} and VAS 5052b .Maximum quiescent current consumption is 50 MiliAmper !!
  30. gupsterg
    348
    On the A6 there is a recall (TSB/TPI) on power tailgate ... will have a nose if one exist/applicable to Q7 ...
    So you still have this error...
  31. vw754
    2,334
    58
    YES I DO.
  32. vw754
    2,334
    58
    JUST DONE THIS ABOUT 30 MINS AGO: VCDS Version: Release 11.11.5
    Data version: 20121222
    Sunday,12,May,2013,21:36:14:07342
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
    55 56 61 62 67 6D 6F 72 76 77
    VIN: WAUZZZ4L07D034266 Mileage: 140010km/86998miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4L0 910 401 M HW: 4L0 907 401
    Component: 3.0L V6TDI G000AG 0030
    Revision: --H05--- Serial number:
    Coding: 0011775
    Shop #: WSC 06144 000 1048576
    VCID: 2C5C11CB8F179978AD4
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 FK HW: 09D 927 750 FK
    Component: AL 750 6A 0940
    Revision: 00H52000 Serial number:
    Coding: 0000504
    Shop #: WSC 31414 790 00001
    VCID: 7CFCE18B3FF7C9F87D4
    Address 03: ABS Brakes Labels: 4L0-910-517.clb
    Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
    Component: ESP ALLRAD MK25E1 0130
    Revision: 00H21001
    Coding: 0038033
    VCID: 2854EDDB9BEFB55849C
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000493662
    Coding: 0000147
    Shop #: WSC 00202 210 80978
    VCID: E3CE3AF722499600DCE
    Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
    Part No SW: 4L1 910 732 G HW: 4E0 035 729
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 386GZ067515771
    Coding: 0002002
    VCID: 2E581BC3B90BEB68830
    Part No: 4L0 910 609
    Component: E0380 BedienteilH01 0060
    Address 08: Auto HVAC Labels: None
    Part No SW: 4L0 910 043 HW: 4L0 820 043 F
    Component: KLIMABETAETIGUNGH05 0060
    Revision: 00---012 Serial number: 00000000153176
    Coding: 0298006
    Shop #: WSC 00202 210 50776
    VCID: E1C230FF38558410CE2
    1 Fault Found:
    00565 - Rear A/C Control Head (Climatronic) (E265)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 139997 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 17:10:50
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    VCID: 316200BFA835F4909E2
    Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
    Component: Wischer AU716 H12 0100
    Coding: 00022806
    Shop #: WSC 31414
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150059
    Shop #: WSC 31414
    2 Faults Found:
    02745 - Bulb for Daytime Running Light; Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 139996 km
    Time Indication: 0
    Date: 2013.05.10
    Time: 17:10:00
    02746 - Bulb for Daytime Running Light; Right
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 140008 km
    Time Indication: 0
    Date: 2013.05.12
    Time: 21:08:00
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4L0 910 111 A HW: 4L0 035 111
    Component: CD-Changer H41 0100
    Revision: 00000000 Serial number: AUZ5ZBF3031364
    Shop #: WSC 00000 000 00000
    VCID: 1E38CB03C9AB7BE8330
    Address 15: Airbags Labels: 4L0-910-655.lbl
    Part No SW: 4L0 910 655 B HW: 4L0 959 655
    Component: 31 AIRBAG AUDI8RH38 0120
    Revision: 05H38000 Serial number: 0037GD06EATC
    Coding: 0013105
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90054061900297
    Coding: 0102142
    VCID: E6C823E3D17BE3283B0
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4L0 920 980 G
    Component: KOMBIINSTR. M73 H17 0110
    Revision: 00300000 Serial number: 5HJ38KC76
    Coding: 2657443
    VCID: 234EFAF7E2C956001CE
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 C
    Component: Heizgeraet H07 0060
    Revision: 0000000E Serial number: 00000009011043
    Coding: 0000002
    VCID: E0C435FB335F8D18C1C
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B067198014
    Coding: F55BBE7F307202
    VCID: ECDC51CBCF97D9786D4
    Address 34: Level Control Labels: None
    Part No SW: 4L0 910 553 B HW: 4L0 907 553
    Component: LUFTFDR.-CDC H03 7550
    Revision: --H03001 Serial number: 15.1528-0095.2
    Coding: 0015510
    VCID: 2952E8DF80E58C50562
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 67
    Mileage: 140011 km
    Time Indication: 0
    Date: 2013.05.12
    Time: 21:08:52
    Freeze Frame:
    Error Code: 13
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 399GY067530247
    VCID: 3B7E22977A790EC034E
    Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
    Component: TSG FA H12 0130
    Revision: 00000000 Serial number: gh‚
    Coding: 0002651
    VCID: 2F6606C7BE01E260886
    Address 46: Central Conv. Labels: 4L0-910-289.lbl
    Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
    Component: Komfortgeraet H05 0020
    Revision: 0020 --- Serial number: 01016072060000
    Coding: 7348475
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 109
    Reset counter: 25
    Mileage: 139057 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 11:22:20
    Address 47: Sound System Labels: Redir Fail!
    Part No SW: 4L0 910 223 B HW: 4L0 035 223
    Component: DSP-AU716 H20 0100
    Revision: 11S00001 Serial number: 01307060320074
    Coding: 0000013
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 E
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000004784
    Coding: 0011101
    VCID: DEB80B03092BBBE8F30
    Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
    Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
    Component: TSG BF H12 0130
    Revision: 00000000 Serial number: uƒ
    Coding: 0002651
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
    Component: AFS 1 H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000022
    Part No: 7L6 941 329 A
    Component: AFS-Modul links H06 0002
    Component: AFS-Modul rechtsH06 0002
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 388GW067540507
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 HW: 4L0 915 181
    Component: J0644 BEM H12 0530
    Revision: -------- Serial number: 00000000029522
    Shop #: WSC 00551 210 86264
    VCID: E4CC39EB27479138254
    Subsystem 1 - Part No: 009 2S5 013 0
    Component: von VA0 536079390A
    Coding: 303039325335303133302056413035333630373933393041
    2 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 67
    Mileage: 140002 km
    Time Indication: 0
    Date: 2013.05.11
    Time: 00:57:10
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 140011 km
    Time Indication: 0
    Date: 2013.05.12
    Time: 21:04:59
    Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
    Component: TSG HL H21 0050
    Coding: 0002058
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
    Component: SDS 3502 UK H45 0630
    Revision: 00000000 Serial number: 00000607050343
    Shop #: WSC 12336 024 394758
    VCID: 366833A3415BD3A8CB0
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 A
    Component: ValeoHeckdeckel H20 0280
    Revision: --H20001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    Part No: 4L0 910 946
    Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
    Part No SW: 4L0 910 290 HW: 4L0 907 290
    Component: ILM HINTEN 2 H05 0060
    Revision: AAH05061 Serial number: 001845617-----
    Coding: 0000001
    VCID: E5CA24EF2C7DE83032A
    Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
    Component: TSG HR H21 0050
    Coding: 0002058
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06320618801916
    Coding: 0201146
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H13 1130
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0010900
    End ---------------------------------------------------------------------
  33. vw754
    2,334
    58
    URL=http://s851.photobucket.com/user/vw754/media/P3_zps0b7ffb31.jpg.html][​IMG][/URL]
  34. vw754
    2,334
    58
  35. christof71
    christof71 Member
    60
    "DONT UNDERSTAND THIS: I did use current clamps 50 amper {importent} and VAS 5052b .Maximum quiescent current consumption is 50 MiliAmper !!
    You have to close the car and wait about 10 minutes."
    Sorry :-}
    when you close the key remote control car, a few minutes later, when all the ECU are sleeping, quiescent current must not be more than 50 mili-amper.
    Each power consumption over 50 miliamper will cause discharge of the battery.
    check the battery history, the best vas 5052b.
  36. christof71
    christof71 Member
    60
    Example of TSB
    t
    2006-09-20,22:18:46*0012 hours 00.71 A, quiescent current
    2006-09-19,16:37:06*0018 hours 00.70 A, quiescent current
    2006-09-19,13:08:12*0000 hours 00.70 A, quiescent current
    2006-09-18,17:23:16*0015 hours 00.70 A, quiescent current
    2006-09-17,20:53:45*0012 hours 00.71 A, quiescent current
    2006-09-17,17:20:20*0001 hours 00.70 A, quiescent current
    2006-09-16,22:05:17*0017 hours 00.70 A, quiescent current
    2006-09-16,19:47:44*0000 hours 00.70 A, quiescent current
    quiescent current over 50 miliamper , 00.70 a in this case, the battery will be discharged
    correct current consumption should be max 00.50A ={ 50 miliamper}
  37. vw754
    2,334
    58
    i have only vcds (vag-com) so cannot check anything else,ive posted some pics regarding the audi portal,if you need more info let me know.
  38. vw754
    2,334
    58
    Ive been told ive done all the main things....ive updated mmi.......updated the nav disc,put in new battery and coded it.
    Some say the auxilary heater drains the battery?...........any ideas where and which the fuse is so i can pull the fuse see if that stops battery draining.........unless you have any ideas?
  39. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Go into VCDS, press Applications, press Erase All DTCs.
    Do a few ignition cycles and rescan.
  40. vw754
    2,334
    58
    let you know when ive done that,cheers,
