Audi Q7 back-up cam cannot be reached?
chris.vincent3 Nov 19, 2017
  1. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    Hi, my dads friend that owns a Q7 that I've been resetting his service light for sometime now as he does his own service and gets me to turn it off with VCDS.
    Reset the service last year and his back-up cam has stopped working since.
    Since then he's checked the camera and all connections which are all fine.
    Came again today to reset the service light again (year later) and the back-up cam still isn't working so I tried to dig into it a bit deeper with VCDS, but I cannot gain access to module 6C - Back-up cam.
    Camera was factory fitted and has been working fine before. Even gone into module 19 CAN Gateway to check installation and the back-up cam is ticked.
    These are the faults that come up on a diagnostics scan. Any help would be great. Thanks.
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4L0 035 670 B HW: 4L0 035 670 A
    Component: H-BNT-EU H49 0143
    Revision: -------- Serial number: 474H10A7536096
    Coding: 010101060004D3EF01002315EF6300030000
    Shop #: WSC 00546 210 84725
    VCID: 275BBE8B56E4987EEB-8072
    Subsystem 1 - Part No: 8R0 060 884 R
    Component: EUR 2010 1107
    Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
    Component: DU7 High H43 0084
    Serial number: 9466HO0A0072051
    Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 B
    Component: E0380 Bedient H05 0060
    Serial number: 00000001637834
    Subsystem 4 - Part No: 8R0 060 961
    Component: CD-Database 1886
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 162
    Mileage: 81013 km
    Time Indication: 0
    Date: 2017.11.19
    Time: 11:39:53
    Freeze Frame:
    Bin. Bits: 00001000 00000000
    Bin. Bits: 00000000 00000000
    Address 6C: Back-up Cam.
    Cannot be reached
  2. NHN
    29,593
    1,782
    Either lost power or module is buggered.
  3. chris.vincent3
    606
    34
    Thanks for the reply. Is it common for the module to go on these?
  4. NHN
    29,593
    1,782
    Common or not, it's an issue, check power feed 1st.
  5. Screw90
    Screw90 Member
    77
    9
    What happens on reverse? Black screen ? Do they sensors( PDC ) works and beeps?
