It's the same no heated seats, also my wheel is on the correct side
My climate control is identical to the one you have posted the video off, only difference is i don't have heated seats, so don't have them buttons.
I've done this and it's working almost perfect except one foult code:
It can not be cleared
Address 08: Auto HVAC Labels: None
Control Module Part Number: 8U0 820 043 B HW: 8U0 820 043 B
Component and/or Version: E87 Klimavoll 0050
Software Coding:
Work Shop Code: WSC 00000 000 00000
VCID: 306B14F3D8E3
Fault Codes have been Erased
1 Fault Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 256394 km
Time Indication: 0
Date: 2014.12.21
Time: 10:37:39
Freeze Frame:
ON
How about your central electronics, part number, sw, hw, etc.?
Maybe mine doesn’t recognize newer climate control unit from Q3?
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009360286
Coding: 95A823A1B4141380EF00001C0000000000094C056401800B006800000000
Shop #: WSC 00899 210 89553
VCID: 489B20EE3B73D761E7B-801D
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 00899
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 B HW: 8U0 820 043 B
Component: E87 Klimavoll 0050
Revision: 00H03000 Serial number: 8U0820043B
Shop #: WSC 00000 000 00000
VCID: 306B680EA3E37FA1DFB-8065
Its just the screen thats white, I thought that has a filter on the screen that would also need to be changed but isn't as easy as just changing the LEDswould be easier to just replace the leds to white .
Software Coding:
VCID: 306B14F3D8E3
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 194
Mileage: 256394 km
Time Indication: 0
Date: 2014.12.21
Time: 10:37:39
Freeze Frame:
ON
Hi, sorry to bring this thread up again but was wondering if you ever found a fix for this fault code. I have fitted a Q3 climate and seem to get the exact same fault code but no way of clearing it with VCDS. Other than that it functions perfectly.
