Audi Parking System on screen
JD007F Oct 7, 2012
  1. JD007F
    JD007F Member
    294
    22
    Hi Guys,
    I'm currently looking to buy an a3, but i want sat nav and front and rear parking senors but i was wondering can i fit theses after i have brought the car will it come up on the screen like on this website below
    Audi Parking system plus installed at the dealer... - AudiWorld Forums
    I think its called audi parking system plus but not sure, also is te sat nav i have seen below the right one for the a3 and is it correct for the parking sensors.
    RNS-E AUDI A3, S3 Navigation MEDIA CHROME. SATNAV, DVD 2012 MAP ... | eBay
    but then could anyone help me with what else i need to get aka what parking sensors etc and can i just fit it all up or does it need activating on VCDS.
    Hope you can clear this up for me.
    Many thanks James
  2. Troubs12
    Troubs12 Member
    92
    10
    Hi James it is possible to retro fit and that's the rns-e you'll need also you'll need the fofollowing:
    parking aid control unit (pr. code 7x2)
    8x sensor holders
    8x parking sensors (4h0919275a or 4h0919275agru)
    2xbuzzers I forget the part number but can get it for you
    4xplastic rivets
    1xparking aid button
    and wiring kufatec do the 4 looms you'll need if you don't fancy making your own
    its easier to retrofit on a 2009 on a3 however not impossible to fit on an 8p1 or 8p2 as me and another member recently got together via email and carried out transatlantic dual retrofits at the same time which was very cool to say the least I'm working on a full guide to post. Also you'll need to code the rns-e to tell it optical park system is installed.
    Also you might have to change the gateway depending again on age of the car there are many threads on this a user called nhn was the first I belive and has covered the coding etc hope this essay helps
  3. phil_w
    phil_w Active Member VCDS Map User Audi A4 Audi Avant Owner Group S-line owners group Team Brill Red
    599
    57
  4. Ash187
    7,489
    741
  5. JD007F
    JD007F Member
    294
    22
    Hi Troubs12,
    Thanks for the quick reply,sounds pretty easy from ho you put i lol, i'm hoping to get a 10 plate a3 so that means it should make life more easier when getting the parking sensors etc. i have seen the webste Phil_w has given below with the full kit is that a good webste to buy from or is there anywhere local ish aka anywhere around cornwall/devon that does the kits and fits/coding etc as i lik to deal local if i can.
    Many thank for the help guys
  6. phil_w
    599
    57
    I think you'll struggle to find complete kits that fully integrate anywhere else as almost all people advertising retrofit kits will normally be a buzzer based system only with no connection to the on board systems. NHN will probably be along soon to say he doesn't like the kufatec wiring looms and :) and I've also often found that their info is misleading and sometimes inaccurate so looms can always be made from scratch which Nigel (NHN) generally does. In fact as I'm typing this, private messaging NHN is probably your best bet as he is down south and will do a better job than anyone on the high street out there anyway as his attention to detail is unparalleled! Just my 2c
    NHN likes this.
  7. NHN
    29,341
    1,719
    Thanks Phil, that would be me & no I dont like kufatec looms lmfao.
    JD (reminds me of Scrubs) PM me if you're looking for a supply/fit solution mate.
  8. JD007F
    JD007F Member
    294
    22
    Hi Nhn,
    I have sent you a pm with an idea what I would like etc hope you understand it. Many thanks
    James.
  9. Ryan21
    Ryan21 New Member
    10
    He fitted mine and can't fault it. You would never know it didn't come out the factor like it!!!
    NHN likes this.
  10. NHN
    29,341
    1,719
    Cheers Ryan, did the little job on weekend go ok fella as didn't hear back :)
    JD just packing up car, will reply shortly.
  11. JD007F
    JD007F Member
    294
    22
    Yeh that's cool Ryan! When you say the parking system is thy with it coming up on the rns-e screen Etc. also may I ask how long it took. I'm viewing one car on the 3rd of July as the garage is closed until then for respects of the owner passing away!
    Cheers no worries if I don't reply straight away I will do tomorrow as I start wrk at 4 in the morning lol.
    Thanks james.
  12. Ryan21
    Ryan21 New Member
    10
    Yer worked fine. Forgot to message you. Yer comes up ok the screen. Fitted mine in 1 n half day.
    NHN likes this.
  13. JD007F
    JD007F Member
    294
    22
    Hi Ryan, yeh that does look the bees knees lol.
    May I just ask anyone in general what sds and mfsw to do with the rns-e I think as Nhn but thought I would pop it on here cheers.
  14. NHN
    29,341
    1,719
    MFSW aka multifunction steering wheel allows control of music, volume, phone (if fitted) sds (speech dialogue system) which allows voice control of the nav for destinations, features of nav, phone for voice dialling, radio features.
  15. JD007F
    JD007F Member
    294
    22
    Hi Nigel.
    Sorry for a slow reply but that's cool sounds good. Can the sds already be on my rns-e in the car as ill check tomorrow. Cheers
  16. NHN
    29,341
    1,719
    Doubt you have full sds already, hardly any spec'd it.
