Audi Navigaton Plus
fattiereturns May 14, 2010
  1. fattiereturns
    fattiereturns A4 2.0T Q
    41
    Hi folks,
    recently got a 2007 a4 with the above double din sat-nav / radio. According to the user manual I should have TV, bluetooth, automatic ball scratcher - the lot!
    Can't see that it has TV, (not on the list of sources) can't see anything referring to bluetooth, (just get a "phone not installed" message) and am scratching nads the manual way. Is there a lower spec unit that probably falls under the same user manual?
    Also, as the map info on this unit is DVD ROM, I'm presuming there's no way to update it with speed camera information, or even the details of mobile cameras which are released weekly? If this is the case I'd more likely care to swap it out. Has anyone ever found a nice aftermarket double din which will do all the functions and integrate with the dash display and wheel controls? I had a nightmare with an older a4, with an aftermarket unit playing funnnies with the bose amplifiers in the speakers - are the newer bose systems still prone being picky about line deadening?
    What a rant eh?
    Cheer folks
  2. Pii
    Pii Member
    748
    The RNSE does not come standard with TV and BT. These are additional devices that can be linked with it.
    No speed camera too on the Audi Sat Nav and no input possibility that I know of.
    After market DD do not look OEM or work with the DIS but you can buy some steering wheel adapters that will work to a degree.
    Sadly the BOSE issue is ongoing so I have been recommended that changing an afrermarket unit would require chaging speakers also.
    Good luck!
  3. HM1975
    HM1975 Member
    33
    34
  4. fattiereturns
    41
    great stuff, thanks lads
    :beerchug:
  5. fattiereturns
    41
    My old A4 had bose system and I put together a couple of little adaptors with capacitors in-line as advised on some website somewhere... :blush:
    Anywhoo, they worked a treat and I happily ran a Kenwood BT / ipod unit for a year or so. The adaptors weren't the prettiest of things but served their purpose. Hopefully that would save me changing out the speakers?
    I've seen the pioneer navgates and they look like pretty slick once fitted with the right fascia adaptor to be honest...
  6. JohnS3
    JohnS3 Active Member
    3,028
  7. BahnStormer77
    BahnStormer77 BahnStormer
    2,756
    53
    anybody tried that yet?
    I've had a Snooper S6 (Snooper EVO) for years and years but the speaker just went pop last winter so now it sounds like a Dalek.... so I've just ordered the Snooper Lynx which does the same thing, plugs into the same 12V hardwiring kit, etc... and does constant updates without needing a PC, including active mobile sites IF somebody else has spotted one... it DOES however need a £8pcm mobile contract :(
  8. JohnS3
    3,028
    Yes I have it working. I like it as it's OEM with no wires and beeping things stuck on the dash. I drive with the RNSe set to 400m resolution and glance down occasionally to see if there are any cameras in my vicinity. Works well for me.
  9. BahnStormer77
    2,756
    53
    Ah - I've seen it now: no notification and only visible on the main screen, not the DIS.
    I'll stick to the dashboard one: no visible wires when fitted properly and only really beeps if you are exceed the speed limit.
  10. andyherd
    andyherd Member
    62
    I've got the same system with TV and phone in my A4, does anyone know how to get them working?
  11. JohnS3
    3,028
    What do you want to get working?
  12. auroan
    auroan Active Member
    1,669
    Have a look on here KUFATEC GmbH & Co. KG - A4 - B7/8E
    Kufatec are expensive compared to some ebay adaptors.... but they work first time every time, and the cabling etc is usually OEM spec.
  13. andyherd
    andyherd Member
    62
    The TV and phone functions on my system, I'm guessing both nedd activation some how
