Audi Navigation System - AUX does not work! Help!!
Becksbar7 Feb 7, 2014
  1. Becksbar7
    Becksbar7 New Member
    29
    Hello,
    I purchased an Audi navigation system which my other half installed the other day. All seems to work, but the original AUX port which is near the handbrake.... Does anyone know why and how I could get around this?
    Your help would be much appreciated,
    Becks
  2. GazJSmithy
    GazJSmithy Member
    52
    9
    If you get an answer to this i would be very interested as I've Also got the same problem
  3. Becksbar7
    29
    Yeap, got it sorted today!! 😁 You need to purchase a £5 32 pin connector from Audi. Becks
  4. GazJSmithy
    GazJSmithy Member
    52
    9
    I'm useless with this type of stuff, once I have the adaptor what do I do with it? Haha
  5. Becksbar7
    29
    Haha!! Same!! I'm a female and I managed to sort it 😁!! Lol. Purchase this part: 1J0 972 977 G - Part Number
    What system do you have? Do you have a picture? Or is it same as mine?
  6. GazJSmithy
    GazJSmithy Member
    52
    9
    I have an RNSE
    My car originally had aux near the handbrake but it doesn't work now I've had my rnse installed lol
  7. Becksbar7
    29
    Same as mine! Mine is under the hand break. I installed my RNSE and then the Aux did not work.
  8. GazJSmithy
    GazJSmithy Member
    52
    9
    So what do I do with the adaptor, sounds a silly question but I really don't have a clue ahah!
  9. Becksbar7
    29
    Purchase this part : 1J0 972 977G and then take the system out and move a couple of pins & it will work. Done mine today and all now works!
  10. Becksbar7
    29
    Purchase this part : 1J0 972 977G and then take the system out and move a couple of pins & it will work. Done mine today!
  11. Becksbar7
    29
    This is where you move the pins to... From the blue quadlock in the back of the RNSE to the new connector. ImageUploadedByTapatalk1392494620.607631.jpg
  12. Becksbar7
    29
    Does your telephone work on yours?
  13. GazJSmithy
    GazJSmithy Member
    52
    9
    Thank you!! I'll phone my dealership Monday and get one then hopefully I'll have my AUX back I've missed it haha
  14. Becksbar7
    29
    Same!! Lots of people say they done like aux because of the leads, but I use mine all the time!!
  15. Becksbar7
    29
    Does your telephone work?!
  16. GazJSmithy
    GazJSmithy Member
    52
    9
    My telephone doesn't work, apparently I need some type of adaptor to get it to work, but My car had a parrot kit fitted so I wasn't really fussed about it
  17. Becksbar7
    29
    Ohhh.... I had bluetooth retrofitted and don't know how to get it to work!!!
  18. Phil-1
    Phil-1 Well-Known Member Regional Rep
    1,994
    637
    Have you paired your phone to it correctly? Switch the ignition on and then search for Bluetooth devices with your phone (Audi ***)
  19. Becksbar7
    29
    Hello - I can find my Bluetooth (KUFATEC) I think it's called. Audi installed it when I purchased my car as it did not have it in it. But, I don't know how I can get everything to work together to display and use telephone on my RNSE . I only retrofitted my RNSE last week and trying to get all the functions to work correctly now. Any help would be much appreciated. Thanks, Becks
  20. Phil-1
    1,994
    637
    Hi Becks. Sorry I thought you had the OEM bluetooth kit.
    Sorry I can't help you 😟
  21. Becksbar7
    29
    Ahhhh, no problem Phil. Thank you anyways. What's the OEM Bluetooth kit? Lol
  22. Phil-1
    1,994
    637
    I have the multi function steering wheel with the "mode & speak" buttons on it. I got a wiring loom from EBay and a BT module. The steering wheel controls the phone and you get the phone number/contacts on the DIS. When I get the RNS E it will also work with that.
    Forget you also get voice control...
  23. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    U never said if u coded with vcds to work with ur AUX and Bluetooth?
    I'm not sure if ur Bluetooth will work as it isn't an Audi one tho.
    To be honest since I got RNSE fitted I use sd cards for music :)
  24. cdewar8
    cdewar8 Member
    62
    Hi i phoned my local audi dealer today and asked for the '32 pin connector' the guy said its just a housing case..is that all i need to get and what do i do from there? Cheers
