audi navigation plus
cookie 1984 Apr 28, 2013
  1. cookie 1984
    cookie 1984 New Member
    17
    hi does anybody know if i can link up a ps3 to the audi nav plus. i got the 2007 a4 b7 if this helps, and what about a dvd player?
    thanks
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    Yup.
    All you need as a RNS-E Multimedia Interface like this.
    Install it and code it for TV using VCDS.
    Using the RCA connectors you can connect the PS2 to the interface.
  3. cookie 1984
    17
    thanks, do you know if this lead varies for the audi navigation plus stereo. and does it just plug straight into the stereo. as for coding how do do that, sorry im not good with this.
  4. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    26,828
    9,795
    What is your location please?
  5. A4Chad
    A4Chad Member
    42
    Hmm.. I'd be interested in hearing how this works too..
  6. jb0o
    2,664
    118
    The interface has a 32-pin plug which plugs straight into the back of any RNS-E stereo.
    The RNS-E stereo then needs to be coded with VCDS (diagnostic tool) to be coded for the TV. It needs to be coded for the TV as the interface is a TV emulator, so when you select the TV option on the RNS-E, you'll get access to the interface.
  7. cookie 1984
    17
    i see but when u say diagnostic am i thinking the machine used for fault codes etc,
  8. jb0o
    2,664
    118
    Any device that can code into the ECU's of the vehicle. The most common tool that most of us in the scene use is called VCDS.
  9. cookie 1984
    17
    and if i use a diagnostic from a garage where do i get the vcds codes from?
  10. jb0o
    2,664
    118
    Here's the coding, you just need to code it for TV: Audi Radio/Navigation System (RNS-E) - Ross-Tech Wiki
    Be aware that most diagnostics from a garage can't code into ECU's they can simply retrieve and clear fault codes. The only software that I'm aware of that can code is VCDS and VAS.
    Loads of members on the forum have VCDS, have a search for you closest one and they'll be able to code it for you.
  11. cookie 1984
    17
    Thanks for this, errr how much will it cost for someone to code it
  12. jb0o
    2,664
    118
    Totally depends on the individual. Most will do it for beer tokens.
  13. cookie 1984
    17
    thanks mate i think its took me like months to try and find out hoe you do it, sounds like you know your stuff
  14. jb0o
    2,664
    118
    Its not too bad tbh. Give me a shout if you need any advice.
  15. cookie 1984
    17
    will do thanks, ill let you know if i get stuck lol
