Audi Nav+ problems
Andi Jun 4, 2012
  1. Andi
    Andi New Member
    19
    Hi all,
    First post, so be gentle ;)
    I picked up a '55 plate A3 3.2 V6 Sportback on Saturday and although I'm loving everything about the car (my previous was a rather tame in comparison A4 '11 plate TDIe) I have a couple of issues with the nav which I'm sure are easy fixes:
    N00b question first, is this the RNS-E you all talk about?
    Second question: When the dealer purchased it (well, car sourcer clever lady) she said the radio received perfect reception. I can't pick up a single station. I know there's a couple of FM boosters in the boot, so I had a look.
    The first (large) one doesn't seem to get any power on any of the connections when I "voltmeter'd" it.
    I presume there should be +12V somewhere? What fuse controls the FM amps - could it be that simple? I did a quick scan of the fuses in the driver's side cubby but couldn't find a blown on in any that seemed relevant from the lookup table.
    Next, the mini amps, I have one on the left hand side, but on the right, there's nothing - just a blue and black cable + connector hanging off the windscreen element. Should there be something like this on the other side too?
    And final question - as you can see from the first picture, I have Phone Prep Low without any useful cradle, just the interface on the dash. Can you get a "universal" holder for the mount that might support MicroUSB on a Samsung Galaxy S3 - or can you add a bluetooth module to that to add a BT function to the car?
    Thanks in advance ;)
  2. s8craig
    1,750
    55
    Probably a broken connection through the boot bracket for the antenna.
    Audi are about to launch some universal cradle plates for charging all types of phones, mini USB, Ipod, Sony Ericsson. I don't know much about them excepyt to say they are wider than the standard cradles for universal mounting.
  3. Andi
    Andi New Member
    19
    Where's the boot bracket located? Is it in the hinges?
    And which line should get 12v? Would be interested in putting some power to it to see if it solves the reception issue.
  4. Andi
    Andi New Member
    19
    Anyone got a bit more detail on where to look and where I should be getting power to the lower amp?
    Also, what's the ETA on Audi's new cradles?
  5. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    Pretty sure the 12V comes through the centre of the coaxial.
