Audi MMI Sat Nav DVD question
210_MIH Feb 21, 2013
  1. 210_MIH
    210_MIH Drive it like u stole it
    108
    Hi All
    I have a stock sat nav unit in my 2006 a3. The disc is scratched so it doesnt load up properly. just wondering if 'any' audi sat nav disc will work if i was to buy it?
    Also if anyone is selling one, let me know.
    thanks
  2. big harty
    big harty Member
    307
    15
    You have to have same year or newer as it uploads latest software mate. Don't buy cheap copies though.
  3. 210_MIH
    108
    Just wanted to revive this thread....got a new disc which my satnav wont read.
    Im guessing the laser may need cleaning or replacing - wondering if there are any decent kits available to do this or do i have to open the unit up?
  4. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    If the 'new' disk you have tried is a genuine Audi nav disk, my advice would be to clean the laser lens. I did mine by pulling the unit out (with the proper keys), just far enough to get the top lid off. No need to disconnect. Remove the DVD disk and turn off the unit. With the lid off, the laser lens can be see right away as it points upwards. I gently cleaned mine with a cotton bud soaked in alcohol. Made a difference I am sure. By the way, I have seen videos of this very thing being done on Utube, so try googling it if necessary. However, if what you put in was a copy, then you need to borrow an Audi disk to test it properly. Good luck.
  5. 210_MIH
    108
    Thanks bud. Will have a crack at this.
  6. nluk100
    nluk100 Active Member
    947
    171
    43
    You could try cleaning the lens with a lens cleaner DVD also - a lot simpler than taking the unit apart and a good first step, usually fixed the problem.
  7. 210_MIH
    108
    Can you maybe recommend one?
  8. Geraldy212
    565
    42
    Don't agree. Most lens cleaners just try to simply brush dust off the lens. I believe that the lenses get dirty due to other issues such as a film of dirt, oil, etc, that does need proper cleaning off. Best way to check is to use a genuine Audi DVD and then if that does not work, clean the lens as above. Good luck.
  9. Cockney Boy
    Cockney Boy Member
    483
    The RNS is easy to take apart and takes about 30 mins to strip down and clean the head. If you've been using copied DVD's then the head needs to work harder which shortens its life. "Buy cheap, pay twice"
  10. 210_MIH
    108
    Thanks guys
    I have used genuine audi DVDs. It was scratched like mad had to give that a good clean also.
  11. 210_MIH
    108
    So...i just thought I'd put some pics up if anyone wants to clean their lens. as i couldnt find a guide. Its very easy and cos tme £10 to do.
    Bought some removal keys and isopropyl alcohol from ebay.
    First removed the stereo.... and opened up the 3 small screws on the top...
    and the four slightly bigger screws on the side.
    Opening the lid it looks likes this on the inside:
    the laser it self is just under the metal housing....
    gave it a good clean with the alcohol, and the cotton bud looked dirty after....no wonder it didnt work
    so I left it for 15 monutes and put it all back together. put in my DVD...
    And it worked a treat! can navigate around the menu a lot quicker and the screen seems crisp as well.
    Miniture guide but seeing as I couldnt find anything to help i thought Id put this on.
    Adam_A3_ likes this.
