Audi MMI radio tuning
Boombastik Aug 19, 2013
  1. Boombastik
    Boombastik Member
    125
    13
    I have the MMI system in my S4 and the radio is basically lost tuning thru all stations
    the signal meter at the bottom gives me 5 bars and yet the radio stations still dont tune in worth a ****
    any one got any ideas ?
  2. NHN
    29,417
    1,740
    Signal bars, those at the bottom are for the Bluetooth phone connection, not radio reception.
    Is it a cab by any chance?
  3. Boombastik
    Boombastik Member
    125
    13
    i thought they might have had something to do with radio signal, no its a saloon
  4. hades-
    9,481
    646
    could be the aerial amp ?
  5. Boombastik
    Boombastik Member
    125
    13
    will i need to take the radio out then to access this amp ?
  6. NHN
    29,417
    1,740
    Yeah was my next port of call the amp & as its a saloon its iirc, above the trim that sits at the top of the rear screen.
  7. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    BTW the B7 doesn't have MMI.
    Yes I know the RNS-E says MMI at startup but that's an idiotic decision by a mad marketing buffoon at Audi that has caused people to spend £200+ on the wrong map DVDs because they think they've got MMI.
    The RNS-E and MMI have absolutely nothing in common - different hardware, different software, different maps, ...
  8. Boombastik
    Boombastik Member
    125
    13
    Got an update for this. I bought keys to pull the radio out and I've found the Ariel connection on the head unit to be loose I took the back plate off and it looks like the soldered spades have broke away from the circuit board. So if I hold the Ariel cable up the radio works fine
  9. NHN
    29,417
    1,740
    Well either needs repairing or replacing, we can look at either option, but I can assure it wouldn't be a cheap fix if its broken the pcb track, possibly new board.
  10. Boombastik
    Boombastik Member
    125
    13
    i'll whip out the head unit one night this week and i'll take some pics of it to show you, if you think it could be repaired would i be able to post it to you for the repair ?
    any idea on the price of a replacemnt unit
  11. NHN
    29,417
    1,740
    You can post yes, but depending on the level of damage, it sometimes is better to change for replacement unit.
    Costs vary tbh, as they are mk1 & mk2 units.
    Send pics & we can have a look, but only a personal inspection would allow a proper analysis for costs.
  12. Boombastik
    Boombastik Member
    125
    13
  13. NHN
    29,417
    1,740
    Well that's definitely been knocked as the plastic housing is broken aswell.
    It needs properly inspecting tbh, so up to you how you want to go forward.
  14. Boombastik
    Boombastik Member
    125
    13
    Can you give me an idea of cost to repair if possible prior to inspecting
