Audi fault for audi brainers
audia3turrbo Mar 13, 2010
  1. audia3turrbo
    audia3turrbo Member
    204
    Hi all i have audi a3 1.8t 1998 model,started getting a slight judder at pull off and its bugging me as i cant/dont no what the problem is,when i pull of it some times dose this also if i am in 2nd/3rd at 30mph it seems like it shuts of the the cars alive again this only dose this a few times a day any answers ?
  2. <tuffty/>
    20,847
    3,687
    Vacuum leak I suspect... check all the hoses/pipes coming off the inlet mani as a start for slipts and cracks etc..
    Block 032 in the engine group on VAGCOM will help to give you an idea of if you have a vac leak, a figure of 5% or more indicates ECU is adding fuel on idle....
  3. audia3turrbo
    audia3turrbo Member
    204
    hi do u no if it could be a coil pack on its way out,or air flowmeter cheers,i dont no what u mean by block 032 ??
  4. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,396
    1,299
    Block 032 is a code for a bunch of data the the car's ECU will return if you monitor it via VCDS (vag-com). This code will give you information about your air/fuel mixture as seen by the lambda sensors. I would say that you need to find someone local with this software/cable and do some checking as you might have some errors codes logged, which will point you in the right direction. Here is a thread that will tell you who can help you.
  5. audia3turrbo
    audia3turrbo Member
    204
    Cheers any one eles have any comments
  6. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Yes, trust Tufftybloke.
  7. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Yeah, if you haven't got a clue what it is how are you going to fix it?
    Just take it into a garage?!
