Audi coupe v6 ecu location?
grant_coupe May 10, 2006
  1. grant_coupe
    grant_coupe Member
    30
    anyone have any ideas where it is located? need to find a code on the box before i can order a chip. cheers
  2. Rev-head
    Rev-head Active Member
    2,987
    Should be located at the back of the Glove box ...if you look under the glove box you should see it there
  3. grant_coupe
    grant_coupe Member
    30
    do i have to take the glove box out? there is a small box aprox 3 inch by 2 when i opened it it was like a resistor is that it?
  4. Rev-head
    2,987
    ECU LOOKS LIKE
    Taking the glove box out does make easier sometimes
    /ubbthreads/images/graemlins/beerchug.gif
  5. grant_coupe
    grant_coupe Member
    30
    cheers mate, thanks for the help.
  6. grant_coupe
    grant_coupe Member
    30
    I checked behind the glove box, and the Ecu wasnt there, i asked a mechanic aswell. Any one have any ideas? ta
  7. Rev-head
    2,987
    it will be there remove the passenger side trim under the glovebox and the glovebox itself, the ECU is sort of wedged really tight up against the bulkhead just above the carpet line. Pull the four plugs on the ECU and slide it out of the steel bracket. /ubbthreads/images/graemlins/beerchug.gif
