Audi Coupe 16v - Cuts out when warm
MrRP May 28, 2008
  1. MrRP
    MrRP New Member
    Hi guys this is my first post, so hi to all...
    I'm posting on behalf of my father this time. He has a 95 (M-Reg) Audi Coupe 2.0 16v.
    He currently has a problem where the car will start fine from cold, drive for about 5-10 mins then cut out, once the car has cut out it wont re-start untill cold again.
    I've checked the coil for spark - which there is, Unplugged the lambda, then the temp sensor and that didn't work. I've checked for fault codes using a vagcom style software and there was none. Also the fuel pump does prime.
    Anyone have any idea what the problem could be?
    Thanks in advance.
  2. audi5e
    audi5e Member
    809
    when the car cuts, does the fuel pump run ok? sounds like a pressure problem?
  3. MrRP
    MrRP New Member
    Yeah, I think the fuel pump is ok. It still primes etc, Although it does sound a little more noisy than normal. I'll check the fuel pressure. Does any one know what the pressure should be?
  4. scotty33
    scotty33 Member
    155
    Hi
    Did you fix this yet? If not it could be the hall sender in the distributor? These can be 'borderline' ie faulty but still functioning, but the engine bay heat makes them fail when warm
    Audi do not sell the hall sender alone, but 'probe distributors'
    http://www.probedistributors.co.uk/
    may be able to help
  5. FG Marder
    FG Marder 3.0tdi V6
    Hi guys i am posting on behalf of my father. He has a 1991 Audi 80 Sport 2.0.
    We could be driving, no problems then the engine would just stop for no reason also when any of the windows are open there is a smell of fumes, don't have a clue where it is coming from had a new exhaust fitted about a month ago and also through gears 1-5 there is a funny noise.:shrug:
    If anyone can help thanks.
  6. audi5e
    audi5e Member
    809
    what do the fumes smell like? fuel or exhaust? "funny noises" could be anything... :) a little more info would help... ;-)
