Audi corrosion warranty? The dreaded brown stuff!
Dan320is Nov 19, 2012
  1. Dan320is
    Dan320is Member
    44
    Guys, I have recently bought an 8P '54 3.2. I have noticed some bubbles which will eventually break through.
    A patch at the top of each front arch and the leading front edge of the sills.
    Has anyone had dealings with Audi regarding this? Is it within their corrosion warranty?
  2. nick9one1
    nick9one1 Member
    74
    if the corrosion is caused by stone chips then no.
  3. hades-
    9,481
    646
    good luck with audi
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    fallen out with audi once or twice over these kick up enough of a stink and they give it "goodwill" though most audi paintshops are **** so id just go and get it fixed at a local
  5. Rom
    Rom Member VCDS Map User
    443
    They will check it's never been repaired. So if non Gen wing, been painted or filled, then no.
    They will use a gauge which will measure the paint thickness.
    And as said, stone chips etc no, anything which has impaired the finish.
  6. d4nny
    d4nny New Member
    Got ine done 2 months ago,Teesside Audi done the claim and then sent it up to there body shop in Newcastle cant fault the work finish is spot on and they put a new wing on took about 8 weeks for the claim to go through.
