Audi connects2 help synphony 2 6 disc in dash
Chillout May 4, 2013
  1. Chillout
    Chillout Active Member
    609
    50
    Hi has anyone fitted a connects2 aux in to a audi synphony2 I bought one and the plugs are different or do I need an adaptor it's the 6 disc model
    cheers
  2. BoutTime
    BoutTime Member
    95
    I did last week. There are two types, one with a Quadlock connector and one with an ISO connector. The ISO connector is what I have and on the back of my Symphony II are four separate rectangular connectors next to the fuse. The connects2 plugs into only one of them. Mine is an early 2007. I believe all Symphony II are ISO except the Symphony II+.
  3. Chillout
    609
    50
    At the back of my synphony 2 it has two plugs one i imagine is the feeds and one is the speakers however the head unit has one spare socket but it doesn't match my connects 2 harness a bit confused last stereo I fitted I traced it and crimped it on a old nova.
  4. BoutTime
    BoutTime Member
    95
    T's is my Connects2 fitted. Does it look like this?
  5. BoutTime
    BoutTime Member
    95
    Or a picture without the connects2 fitted......
  6. Chillout
    609
    50
    Yes it looks the same without I have the two black horizontal plugs without the connects 2 but not the red vertical one the middle socket on the hu is also empty but I don't have the red adaptor shown in the fitted photo ?
  7. BoutTime
    BoutTime Member
    95
    Okay. The red vertical connector is for the Audi phone so no worries there. You therefore do need the same unit as me which is CTVADX001. It should come with the harness which plugs into the Symphony II. The original connector then plugs into the connects2 harness red connector as per the photo.
    Chillout likes this.
  8. Chillout
    609
    50
    Cheers I have model ctvadx002 as on the connects 2 site it says its 2003 on as my cars an 05 that's why I went for it but I can see now that your correct thank you very much for your help .
  9. BoutTime
    BoutTime Member
    95
    No worries, I nearly did the same. The Dension website has a very good tool for correctly identifying your head unit and connector.
  10. Chillout
    609
    50
    Before I posted this query I raised a support ticket with connects 2 thinking they might send me the harness the same as yours however they replied to say the dont make one that works with the synphony 2 6 disc in dash changer with cassette just wanted to confirm you have the same unit ?
    cheers
    Brendan
  11. BoutTime
    BoutTime Member
    95
    They said the same to me. It's bol#@cks. It works because the Symphony II accepts an external cd changer too and the connects2 emulates a cd changer. It works!
  12. Chillout
    609
    50
    Thought as much I even wonder if the unit is the same with a different harness I will return mine and order the correct one the technical support with them is not very good a few emails and I still wasn't convinced by them.
    many thanks again
  13. BoutTime
    BoutTime Member
    95
    Their tech support is **** if they don't even know their own product compatibility. That's why I used the Dension website.
