Audi Connect retrofit
ConS3 Feb 2, 2014
  1. ConS3
    ConS3 Active Member
    409
    157
    43
    Hey guys. Not sure of the answer. Down here in Oz, we don't have the option of speccing Audi Connect on the S3. We also have very limited services for those models that do get Audi Connect. Regardless, does anyone know if it can be retrofitted some how?
    SlightlyYapper and OZAudi84 like this.
  2. OZAudi84
    OZAudi84 Member
    54
    I second this question if anybody is able to help.
    SlightlyYapper likes this.
  3. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,574
    1,575
    Try contacting these guys A3 8V - 2012> and see if they can offer any advice..
    ConS3 likes this.
  4. 97catalunya
    97catalunya Active Member
    546
    161
    43
    I would be interested to know if this can be done also?
    I ordered the tech pack but no audi connect as I didn't think I would use it much, but I have now changed jobs so spend a couple of hours each day enjoying the commute in the my A3 so would really find the live traffic useful!
  5. cuke2u
    5,574
    1,575
    At least you'd need the unit that goes in the glove box, then a new screen, which might not fit in the dash. The associated wiring and a gps aerial...
  6. ConS3
    ConS3 Active Member
    409
    157
    43
    Why would we need a new screen? We have sat nav and MMI as standard here. Same screen you guys get. Which also means we have the wiring/antenna.
  7. ConS3
    ConS3 Active Member
    409
    157
    43
    Thanks for that. I dropped them an email, as there is nothing listed on their site. I'll see what they say.
  8. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,522
    1,145
    Shouldn't need a new screen, it's the same as the standard tech pack. As for whether you need a new MMI unit or not, I don't know - the telephony equipment might be in all the models but disabled in some. There are licences involved for some things though (like text message dictation)
  9. cuke2u
    5,574
    1,575
    The MMI system with the SD card used a 5.8" screen and the Audi connect uses a 7" screen with a high resolution. I doubt if the graphics card will be compatible with the lower resolution, smaller, screen, as has been stated before. I was only suggesting that the screen also might be physically larger, all well and good for fitting the higher resolution one if they are the same size...
  10. ConS3
    ConS3 Active Member
    409
    157
    43
    I should have mentioned that as well. We get the higher res 7" screen here. It's actually standard on the car, not even an option. So that's not an issue.
    I've heard back from Hazzy Dayz on what can be done, and it turns out nothing. Audi Connect requires an account that must be configured to connect to the Audi servers to enable the services. Go figure haha. More proprietary stuff!
    So, the only real way to get it to work would be if Audi comes out with kit themselves. Even then, not sure how it would work.
    OZAudi84 likes this.
  11. cuke2u
    5,574
    1,575
    That's good about the screen, halfway there. Just needs somebody brave enough to do it, maybe a unit from a scrapper?
  12. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,671
    519
    But Connect uses Audi servers to provide the information to the car, I can't see Audi offering to setup Connect accounts for retro-fitted cars therefore even with all the correct hardware it'd be unlikely to do much good.
  13. cuke2u
    5,574
    1,575
    That's it then, sorry I missed that bit in ConS3's post...
  14. ConS3
    ConS3 Active Member
    409
    157
    43
    I work in IT, and the way Audi has designed this system goes back to the stone age almost haha. I've dug around, and found a few more reasons as to why a retrofit isn't possible:
    1. Google maps are cached on the unit. The hard drive on the Audi Connect version is larger to accommodate for this.
    2. Here's the killer (the nerd in me speaks!). Audi has actually hard coded the devices access point to the UMTS module, and it can't be changed. Not only that, but the UMTS module itself also can't be changed. Who actually hard codes these things still? I guess Audi!
    The only real way to get this to work is to buy a complete unit from Audi with the Connect services. I can't picture anyone wanting to do that simply to get Facebook in their car.
    Bandicoot51 likes this.
  15. OZAudi84
    OZAudi84 Member
    54
    Very informative Con.
    Apart from Google Maps though, I'd have little use for FB and Twitter etc. in the car. I had online connectivity in my A45 and found it to be pretty much useless.
  16. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    951
    394
    I can't comment on whether Audi hard code modules but suspect their approach to prevent this is for security ie To avoid a repeat of the near rampant theft from vehicles and retrofit that afflicted the 8P RNS-E Sat-Nav units.
    A related secondary effect is to stop people trying to retrofit & get more purchases at time of order.
  17. cemerson
    4,522
    1,145
    How do you know this?
  18. ConS3
    ConS3 Active Member
    409
    157
    43
    Research, and speaking with a few companies who offer retrofit kits for other components of VAG cars.
  19. cemerson
    4,522
    1,145
    Hm, that's a shame. I was hoping to be able to change the endpoint to a custom one at some point. There are other ways around it I'm sure, bit still a bit annoying!
  20. mjcourtney
    1,671
    519
    snowfree52 and cemerson like this.
  21. mjcourtney
    1,671
    519
    snowfree52 likes this.
  22. Schizophonic
    Schizophonic Well-Known Member
    825
    419
    That's amazing. Didn't know there would be detailed information like that.
    On a side question I've got the standard screen. Can I get the high end kit (higher res screen) and the hard drive version would it be a straight swap?
  23. mjcourtney
    1,671
    519
    I don't think so. Because the screens are different resolutions they need different control units to drive them. The high res screen needs the full "tech pack" processor unit to drive it (the bit with the DVD Drive and SD Slots in your glovebox), which also means a new input / touch controller in the centre console. There may be other wiring harness changes etc.
    It might be possible, but I suspect by the time you've bought the high res screen, the "tech pack" processor unit and the touch controls you'd be looking at well over £1k just in parts. A chap on here did try just plugging in the high res screen into the standard MMI system and it wasn't compatible.
  24. ErVaLt
    ErVaLt New Member
    15
    10
    Hi guys, reviving an old question maybe...
    Would it not be possible for those with the standard SD satnav 5.8" that just want a bigger screen (no resolution or anything) to simply make a panel and controller swap inside the monitor unit?
    Similar to what the NaviTouch does but without the touchscreen panel.
    Schizophonic likes this.
  25. cemerson
    4,522
    1,145
    God, why would anyone want to replace the 8V screen with a touchsceen? The MMI is a great input method
  26. Schizophonic
    825
    419
    This is such a simple yet effective idea. The risk look minimal and no real issues. Definitely going to be looking into this! Great work!
  27. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,759
