Audi Concert - Speakers crackling B7 A4 Avant
Richardlkay75 Dec 19, 2012
  1. Richardlkay75
    Richardlkay75 New Member
    Hey guys
    I currently have an issue with my B7 A4 Avant whereby the speakers will crackle intermittently. It's not caused by anything specific eg; bumpy roads or cornering etc, just as and when it feels like it. It's been getting progressively worse over the last week or two to the point this morning that the system would crackle, then blast out on top note, then go quiet for a few seconds before slowly returning to normal.
    I had the head unit out yesterday and checked all the connections behind there and all is OK as far as I can see. I've also checked the connections on the amp and sub speaker in the boot and again, all appears to be OK. I've yet to disconnect the amp and just power up the HU to see if this makes any difference.
    It's a completely standard OEM install. I've tried searching but it's not bring up much (maybe that's just me!)
    Thoughts/suggestions please.
    Ta
  2. AndyMac
    9,832
    45
    Is it a Bose system or non Bose.
    The Bose amp suffers from the main solder joints drying out which will cause this issue, usually worse on cold mornings, improving when the amp has warmed up.
    Non Bose then you need to check the connectors on the A pillars behind the rubber boots between the door hinges as these can get "electrically dirty" and cause intermittant break up, but this is usually resolved by jacking up the volume.
  3. Richardlkay75
    Hi AndyMac
    It's a non Bose system. I'll check out the connectors as suggested. Cheers
