Audi Concert Removal
Chris Eaton Jun 7, 2014
  1. Chris Eaton
    Chris Eaton Member
    85
    25
    Hi, I am having difficulty removing the radio from my A3. Can anybody give me some advice please.
    This is my radio:[​IMG]
    I am currently trying with 4 of these keys:[​IMG]
  2. ItsAllGood
    ItsAllGood Member
    279
    Turning on the ignition to unlock the radio idk try that
  3. Lewbo
    Lewbo Well-Known Member
    1,272
    106
    Flat part of the ring faces inwards, just push all 4 in and pull out simples.
  4. fangio
    fangio Well-Known Member
    1,531
    185
    Pull the top out a fraction, pulling the keys out-over as you pull, then do the bottom and it should slide out as you pull the bottom ones.
  5. lgooch
    lgooch Well-Known Member VCDS Map User
    1,204
    172
    push keys in flat side to the left until they click and give it a yank.
    yours will be stiff as you have a parrot installed and the wire squeezed at the side of the radio will be compressing the radio to the right hand side. this maybe why it feels as if it wont want to come out.
    oh and you will have to remove your parrot to slide it all out.
  6. Chris Eaton
    Chris Eaton Member
    85
    25
    Thanks for the tips guys. In the end I pushed it out from behind by removing the heater unit.
    With the parrot unit it was jammed in. Iv removed that now :)
