Audi Concert not working after window regulator replacement
CraigWonn8P Jun 16, 2013
  1. CraigWonn8P
    CraigWonn8P New Member
    15
    Good day all,
    As above, I have just replaced the window regulator on my drivers side, connected everything back up, all screws in place and everything was fine.
    However, now my radio will switch on, play for about a second then fade out and only slight distortion noise is heard. Radio has been taken out and put in my other car, which works fine but as soon as its put back in the A3, nothing.
    Can anyone provide some advice?
    thanks in advance.
    Car is a 2004/5 A3 1.6FSI if thats of any use.
  2. NHN
    29,298
    1,701
    Disconnect battery, then reconnect after few minutes, see if its got all confused, check you haven't caught any wires in the door, that may cause some abrupt reaction from other systems.
  3. CraigWonn8P
    15
    Unfortunately tried disconnecting, but still not working. I've contacted Audi and just waiting on a response now.
    Taken off the door card and everything is in order. Surely cant be something to do with ECU?
  4. NHN
    29,298
    1,701
    Ask Brodster if he can scan it for you as he's up your way.
  5. CraigWonn8P
    15
    Thank you, I'll see if I can give him a shout.
    Hopefully there will be no more silence!
  6. Sidhu88
    Sidhu88 Active Member
    808
    76
    Checked fuses? panel between dashboard and drivers side door
  7. CraigWonn8P
    15
    Checked all fuses and completely stumped as to what it could be. Usually pretty good with problem solving when it comes to my a3 but this is really bugging me. Everything powers up as it should, I get a seconds worth of sound then dips out. Might check the amp and see if it's powering up properly. Anyone know where that's located?
  8. Sidhu88
    808
    76
    behind the nearside boot panel. If ur running a non bose system u'd still get sound from headunit. If ur running bose then everything runs from the amp. What stereo have u got in the car? Are all the speakers standard? and have u checked the speaker connections on the door u changed the window regulator on?
